Front emblem help
Old Apr 14, 2011 | 02:57 PM
mickey_7106's Avatar
mickey_7106
Default Front emblem help
what do you guys use to stick it back on? i had to take mine off cause it looked like someone was trying to pull it off by one of the flags. it had some type of clear adhesive on it. very thin
Old Apr 14, 2011 | 03:09 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
For the time and bother, your better off just getting a new one for 20-30 bucks, the adhesive is a pain to get off, I used googone and alot of rubbing, a hair dryer will help soften! GL
Old Apr 14, 2011 | 03:26 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
take a wire brush and get all that double sided tape off. Then wash it good. Then take your fingers/hand and roll off the tape on the car. Then I used mean Green and cleaned the area really well. Then I used some dawn dish soap and cleaned off the area again. then rinse/wipe the area with clean water to get all the soap off.
I used scotch weather resistant double sided tape and put it on the emblem. It's a pain to get it on the emblem as you have to put it on the emblem and then cut the excess off. But it's doable just be patient. I used a carpenters blade/utility knife.
Then put the emblem back on the car pressing it with your hand. Of course take the tape cover off first
I replaced the back so I was able to then lay a towel on the emblem and then put 2 of my FSMs on it to hold it in place good until it set up. I left it overnight.
Then I used some meguiars quick detailer to get my shine back until I wax again.
Now go take a drive come back and have a beer. It's a thirty minute job.
I also used my grinding wheel with a wire wheel to get the tape off the emblem, but if you do this be careful or you'll grind your emblem.
Old Apr 15, 2011 | 10:40 AM
3M double sided tape will work well to reattach the emblem. Just be sure you clean all the old stuff off both the emblem and the car.
Old Apr 15, 2011 | 12:53 PM
DavzC5's Avatar
DavzC5
From: Houston, TX www.djmotorsportaccessories.com Specializing in C5 & C6 Accessories. DJ Motorsport Accessories.
St. Jude Donor '08-'09
I have (4) new ones here. They don't have the rubber tabs but will work for nose or trunk. $40 each shipped. My paypal is DJ@DJSMCO.COM David
Old Apr 15, 2011 | 02:18 PM
SaberD's Avatar
SaberD
3M mounting tape is where its at.
Old Apr 15, 2011 | 06:49 PM
SG Lou's Avatar
SG Lou
Rubber Tabs ?
ya lost me............
Old Apr 15, 2011 | 07:02 PM
DavzC5's Avatar
DavzC5
Front nose emblems have two plastic/rubber tabs that go in the holes on the nose on the car. The rear/trunk lid emblems do not have the tabs but are the exact same size..so you could use them on the fronts if desired. Plus they are less expensive that tabbed ones.
Old Apr 15, 2011 | 07:34 PM
RetiredSFC 97
If you get new ones I would go with the ones for the back and forget the tabs.
$40.00 shipped is a good price for brand new.
Old Apr 15, 2011 | 08:39 PM
mickey_7106
Thanks. this one is already clean and free of any old adhesive.
is it thin? im worried it might be to bulky
thanks but no thanks. im spraying my old one completely black
Old Apr 15, 2011 | 08:48 PM
SG Lou's Avatar
SG Lou
That I know as I had my front emblem off already. It's the nomenclature that threw me off. I usually referred to anything like them as locator pins.
No harm done
And yes, the rear emblem is a hell of a lot cheaper then the nose emblem.
As long as you locate it properly for front end use the "rubber tabs" are not really needed.
Old Apr 15, 2011 | 09:08 PM
SaberD's Avatar
SaberD
its the same thickness as the factory adhesive.
To Front emblem help
