power antenna help needed
Old Apr 14, 2011 | 10:55 PM
wetelvis's Avatar
wetelvis
Default power antenna help needed
Trying to get the old mast out was full of fun mishaps and stupid mistakes Had to cut the mast then I stupidly pushed it back in thinking I could get it out the way I did at first (doesn't work that way). I managed to get the retaining clip out then the mast just dropped out of site. Got a coat hanger and managed to get the mast out but no plastic cable is attached Guessing the motor will have to come out. So how do I get the motor out? I've got bracket and ground wire bolts and what looks like the power connecter unclipped but there is still the actual antenna cable and some other wires going into the trunk. How do I disconnected them and what do I need to do once I've got it out?
Old Apr 15, 2011 | 01:11 AM
01magnetic01's Avatar
01magnetic01
Here you go.....
http://forums.corvetteforum.com/c5-g...g-antanna.html
Old Apr 15, 2011 | 01:35 AM
DeeGee's Avatar
DeeGee
Here's the procedure with pictures:
Document ID# 384262
2002 Chevrolet Corvette
________________________________________
Power Antenna Assembly Replacement
Removal Procedure
Pic 1
1. Open the rear compartment lid.
2. Check to be sure that the ignition switch is in the OFF position.
3. Remove the RR end/corner carpet trim panel. Refer to Trim Panel Carpet Replacement - Rear Corner in Interior Trim.
4. Remove the RH decklid support trim panel.
Pull to release the retaining clips.
Pic 2
5. Pull back the edge of the rear compartment floor carpet from behind the RH decklid support, then reposition the RH side of the carpet.
6. Release the antenna coaxial cable and wiring harness from the retaining clip on the rear of the wheelhouse.
7. Disconnect the power antenna coaxial cable from the power antenna coaxial extension cable.
8. Disconnect the antenna electrical connector from the front body wiring harness connector.
Pic 3
9. Remove the screws retaining both of the RH taillamps.
10. Remove both of the RH taillamps.
11. Disconnect the antenna ground connector from the rear body wiring harness.
Important
Use care not to twist and damage the ground straps when removing the retaining nut.
12. Remove the nut retaining the antenna dual cable strap (1) and antenna short braided ground strap (2) to the rear fascia retaining stud, then reposition the straps.
Pic 4
13. Remove the nut retaining the antenna long braided ground strap to the rear bumper impact bar stud, then reposition the strap.
14. Remove the antenna bracket retaining nuts.
15. Release the antenna bracket from the mounting studs.
16. Reposition the antenna body (with bracket) toward the RR tire.
17. Using a slight twisting motion, pull down to release the antenna from the antenna bezel.
18. Release the antenna wiring harness grommet from the rear compartment panel, toward the outside of the vehicle.
A. Starting from the outer lip of the grommet, on the outside of the vehicle, begin to unseat the bottom right area of the grommet.
B. Using a flat bladed screwdriver or other suitable tool as an aid if necessary, work around the base of the tapered lip of the grommet on the inside of the vehicle, while simultaneously finessing the outer lip of the grommet on the outside of the vehicle, in order to release the grommet completely from the rear compartment panel.
19. Remove the antenna wiring harness and grommet from the opening in the rear compartment panel toward the outside of the vehicle.
Pic 5
20. Carefully remove the power antenna from the vehicle through one of the taillamp openings.
Pic 6
21. Remove the bolts retaining the antenna bracket to the antenna, if bracket removal is necessary.
22. Remove the antenna bracket from the antenna, if necessary.
23. Remove the antenna bezel upward through the quarter panel, if necessary.
Installation Procedure
Pic 6
1. Install the antenna bezel to the quarter panel, if removed.
Align the locating tab on the antenna bezel to the notch in the quarter panel, then insert the bezel and push to secure.
2. Install the antenna bracket to the antenna, if removed.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Important
Use care not to twist and damage the ground straps when tightening the retaining nut.
3. Install the bolts retaining the antenna bracket to the antenna, if the bracket was removed.
Tighten
Tighten the radio power antenna bracket retaining bolts to 10 N•m (89 lb in).
Pic 5
4. Carefully install the power antenna to the vehicle through one of the taillamp openings.
Pic 4
5. Apply sealer to the groove on the antenna wiring harness grommet.
6. Apply a light coating of lubricant to the narrow end of the antenna wiring harness grommet to aid in seating the grommet.
7. Install the antenna wiring harness and grommet through the opening in the rear compartment panel toward the inside of the vehicle.
8. Fully seat the antenna wiring harness grommet to the rear compartment panel.
9. Position the antenna upright, toward the RR tire and align the top of the antenna with the opening in the antenna bezel.
10. Install the antenna to the bezel.
Insert the antenna up through the opening in the bezel, then check that the antenna and the bezel are seated properly.
11. Position the antenna and install the antenna bracket onto the mounting studs.
12. Install the antenna bracket retaining nuts.
Tighten
Tighten the radio power antenna bracket retaining nuts to 12 N•m (106 lb in).
13. Install the antenna long braided ground strap to the rear bumper impact bar stud.
14. Install the nut retaining the antenna long braided ground strap to the rear bumper impact bar stud.
Tighten
Tighten the radio power antenna long braided ground strap retaining nut to 5.8 N•m (51 lb in).
Pic 3
15. Install the antenna short braided ground strap (2), then the antenna dual cable strap (1), to the rear fascia retaining stud.
16. Install the nut retaining the straps to the rear fascia retaining stud.
Tighten
Tighten the radio power antenna short braided ground strap and dual cable strap retaining nut to 5.8 N•m (51 lb in).
17. Connect the antenna ground connector to the rear body wiring harness.
18. Install both of the RH taillamps.
19. Install the screws retaining both of the RH taillamps.
Tighten
Tighten the taillamp retaining screws to 2 N•m (18 lb in).
Pic 2
20. Secure the antenna coaxial cable and wiring harness to the retaining clip on the rear of the wheelhouse.
21. Connect the antenna wiring harness electrical connector to the front body wiring harness connector.
22. Connect the antenna coaxial cable to the antenna coaxial extension cable.
23. Install the edge of the rear compartment floor carpet behind the RH decklid support.
Pic 1
24. Install the RR end/corner carpet trim panel. Refer to Trim Panel Carpet Replacement - Rear Corner in Interior Trim.
25. Install the RH decklid support trim panel.
Align the panel, then push to secure the retaining clips.
26. Close the rear compartment lid.
Old Apr 15, 2011 | 01:46 AM
wetelvis's Avatar
wetelvis
Thanks for the link. I did manage to get it out I just reverted back to my childhood when I would take everything apart to see how it worked (drove Dad crazy cause I would never put it back together). Funny thing took the motor apart but couldn't find any plastic cable pieces. I think someone had attempted to fix it gave up and unplugged it. Now the motor is working when turning on and off the radio but I'll wait till tomorrow to install the mast. My wife would be pissed if I woke her up to turn off the radio while I guide the mast in. Actually she gets pissed any time I wake her to to guide something else in
To power antenna help needed
