Anti-Theft
Old Apr 15, 2011 | 05:48 PM
Toms02C5's Avatar
Toms02C5
Default Anti-Theft
Last week, when I turned the ignition to start, nothing would happen, just the fuel pump whine. Wait a bit, try again and it would start like normal. Happened several times over 5-6 days.
Finally found out that the issue was the anti-theft. Wasn't reading the code from the key....thought this was a bit weired.
Anyone else had this issue?
Old Apr 15, 2011 | 05:53 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Nope....since it sounds somewhat intermittent I'm worrying if it may be a battery issue with the fob?
Old Apr 15, 2011 | 06:06 PM
zagger's Avatar
zagger
Many C5 vettes have issue with dirt in the lock mechanism. I have read on couple threads how guys take the lock apart and clean it with alcohol, do a search.
Old Apr 15, 2011 | 08:18 PM
Toms02C5's Avatar
Toms02C5
My first thought as well - had the battery checked first thing, it was good. Codes thrown showed it was in fact the anti-theft. Had a new switch, etc. installed and all is well so far. I'd just never heard of this problem before or seen anything relating to it.
Old Apr 16, 2011 | 03:35 AM
dougbfresh's Avatar
dougbfresh
Try SEARCHING above-happens all the time.
Old Apr 16, 2011 | 08:28 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The key contacts at the entrance to the ignition switch are probably worn out.
To Anti-Theft
