What will yours do???
Old Apr 17, 2011 | 06:51 PM
buckg2's Avatar
buckg2
Default What will yours do???
I have an 04 vert, A4, VaraRam, XS headers/hi-flow cats, GHL's,3:15 rear, mail order tune, new Bridgestone tires. I know this is as simple as it comes for bolt ons, but I've never been to happy with the power. At a stop with TC off it will spin the tires but not to the point where you say I should let off this is scary. It will catch a little tire after take off when it shifts into second. I'm not looking for a rocket ship (yet). I just want to know what it should be doing. Maybe I need an in-house tune??
Old Apr 17, 2011 | 06:59 PM
Jistari's Avatar
Jistari
An A4 with the 2.73 rear end is not exactly a "burn out machine"
You have to work at it a bit, maybe a little brake (I was doing that wrong back when the car was new to me and I was "exploring the envelope"). For a while I thought something was wrong or it was underpowered but have come to understand that a whole lot of engeneering went into NOT making the wheels spin from a start.
A big smokey burn out for a mostly stock A4 with the 2.73 is going to take a little cheating (brake).
Im over it
(same thing, Coupe, A4, blackwing and cat backs)
Old Apr 17, 2011 | 11:20 PM
mooney201's Avatar
mooney201
2nd gear, 3000 rpm, mash the throttle, and the rear comes around. 3rd gear 3000 rpm, mash the throttle, and it goes straight.
Old Apr 17, 2011 | 11:26 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
A higher stall torque convertor and a Chuck COW tune will cure your problem.
Old Apr 17, 2011 | 11:45 PM
ColeTrain'sC5's Avatar
ColeTrain'sC5
3000 RPM's and let the clutch out and the thing will smoke them all the way thru half of 3rd gear but by then the tires heat up and start to stick. If i leave gently it won't start to cut them loose until about 5k rpm's in 1st gear. That's due to the cam i'm running as it's torque curve is higher than a stock cam so it doesn't bust 'em loose as easy from a dig. When i was stock it did a better low rpm burnout. But HOLY crap does it fly once you hit about 3k RPM's in any gear
Old Apr 17, 2011 | 11:56 PM
StingrayRebel's Avatar
StingrayRebel
most people are more worried about how to keep their tires from spinning rather than trying to spin them... traction can win lots of races, i wouldn't worry about if i was you... and just because you can smoke your tires doesn't mean you're fast and isn't a good tool to judge what power level you're at either... just take it to the track and see what it runs and let the times do the talking
Old Apr 18, 2011 | 12:52 AM
ksvette74's Avatar
ksvette74
everytime it does not do a burnout, u save about $100 bucks in expensive tire rubber. Be happy!!
Old Apr 18, 2011 | 12:58 AM
ColeTrain'sC5
with my new tires i don't even spin them much anymore.
Old Apr 18, 2011 | 01:00 AM
Jistari's Avatar
Jistari
Reading is your friend......he was asking about an automatic
Old Apr 18, 2011 | 06:22 AM
Dag Skagney's Avatar
Dag Skagney
and he went from a 315 rear to a 273 in only 1 post,,now thats quick
Old Apr 18, 2011 | 09:55 AM
Polar Jet's Avatar
Polar Jet
My car seemed to burn rubber pretty good despite it being an A4 with 2.73s. It is much better after adding a 3.42 diff, a Yank SS3200 stall and a Chuck C.O.W. tune to the mix... and sounds good doing it after a complete exhaust upgrade.
Old Apr 18, 2011 | 10:50 AM
buckg2's Avatar
buckg2
I didn't mean this to be a burn out theard. I didn't know how else to compare acceleration and SOTP power without actualy going to the track. The ability to break normal street tires loose seems to be a real world test. Also like when shifting to second in A4 and breaking the tires loose a little shows your putting some power to the ground. I'm just trying to compare. Seems like often some guys with bolt on mods are saying sit down your in for the ride of your life.
Old Apr 18, 2011 | 07:01 PM
zeevette's Avatar
zeevette
If you wanted a real performance car, why'd you get one with a crappy 4-spd A/T, and lousy gears? You sound like you're disappointed in your car's acceleration. I suggest you invest in a PD supercharger; problem solved!
Old Apr 18, 2011 | 07:20 PM
Jims2001's Avatar
Jims2001
Hey Steve, Our set up's sound about the same and I have to let off the throttle when lighting them from a stop or it will not stop. On the highway if I smash it between 50-60 mph it will go sideways, scary. Jim
Old Apr 18, 2011 | 07:25 PM
Dominic Toretto's Avatar
Dominic Toretto
Breaking traction does not mean you have a lot of power. Crappy tires on a Corolla will break traction. Just sayin.
-Alex
Old Apr 19, 2011 | 12:26 AM
mooney201's Avatar
mooney201
Your question was reasonable,,, our answers were not.
If you want style,,, buy a Corvette.
If you want speed, buy a Ford...
Ford GT40 vs ZR1,,, Ford wins.
Ford GT500 vs. Z06,,, Ford wins.
Style,,, Corvette wins.
Of course a GT40 does have style.
Old Apr 19, 2011 | 12:34 AM
1redz06's Avatar
1redz06
Wow...I think what you ment was if you want a 4000LB boat gt500 wins..
To What will yours do???
Old Apr 19, 2011 | 12:51 AM
mooney201's Avatar
mooney201
That is just the point,,, here the GT500 is a 4000 lb. boat that will out run our Vette's. Sad but true.
Old Apr 19, 2011 | 01:43 AM
zeevette's Avatar
zeevette
I've read several comparos, and the GT500 is always dead last. All parameters, including acceleration, cornering, and road track lap times aren't even that close. Some have the Porsche Turbo ahead in some parameters, but the ZO6 always has the best track time, even when the stupid writers pick whatever German car that's in the test as their favorite.
Old Apr 19, 2011 | 03:17 AM
ShawnFate's Avatar
ShawnFate
Yep , never seen the gt500 come out on top .
In the real world it's gonna come down to the driver .
