need mechanic help
Old Apr 25, 2011 | 02:07 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
There you are!! Thanks very much for replying.
All us shade-tree troubleshooters like to know what the final verdict is.
I still vote EVO steering position sensor.
Did you check codes?
Old Apr 25, 2011 | 03:12 PM
convertible lover's Avatar
convertible lover
I did check codes. This car always has several history codes in it, but nothing to do with power steering. The closest code to that, would be one about the telescoping steering wheel not saving the memory. How would I go about checking the EVO steering position sensor?
Someone else asked about the Z51 Packege. Yes it does have it. Does that mean it should have a power steering cooler?
Old Apr 25, 2011 | 06:18 PM
Jet-Jock's Avatar
Jet-Jock
Yes, if you have Z51 RPO then you have the power steering cooler. It sits on the steering rack between the fans and engine. You can miss it looking in the engine compartment.
So with a cooler installed, and you have these other issues, then I would start to isolate that overheating fluid. Need to look at the FSM to what's up on this one.
Old Apr 25, 2011 | 06:37 PM
Jet-Jock's Avatar
Jet-Jock
Those who referenced "EVO steering position sensor", what is that?
I have reviewed the FSM and see no reference to a term like that or anything similar.
Back to the OP, what is the age/condition of the drive belt?
What position is the belt tensioner sitting at, there are marks on the body of it.
Old Apr 25, 2011 | 09:17 PM
convertible lover
Not sure what Marks you're talking about on the tensioner. But the belt is at least 5 years old, but looks in very good condition.
Old Apr 25, 2011 | 10:04 PM
Jet-Jock's Avatar
Jet-Jock
The tensioner will have a centerline mark and its case will have generally 4-5 tick marks. As the indicator moves more towards the less tension position, means it's wearing out.
Old Apr 25, 2011 | 10:09 PM
Oh 2 Fun's Avatar
Oh 2 Fun
Well, I might be talkin' out me **** but I was ASSuming GM technology for steering would not change all that much from 1998 into the 2000'
s and from model to model.
A '98 Chev pickup I had was having similar problems with the steering. Steering inputs would be difficult sometimes and overly-easy other times. It turned out to be the steering wheel position sensor and was also referred to as an EVO sensor. EVO standing for "Electronic Variable Orifice" that controlled pump fluid flow/pressure depending upon speed and other inputs such as how fast the steering wheel input was being turned (from the position sensor).....this all resulted in the variable assist steering we all enjoy....it makes it easy to parallel park and stiffens up the steering at speed.
So I was hoping someone might now if that applies to our Corvettes...since it is a GM technology product.
Old Apr 25, 2011 | 10:23 PM
convertible lover
If I am looking at the right marks, It looks like it has two marks then a space almost like there is a mark missing then one more mark. It looks like it is about on the second mark
Old Apr 25, 2011 | 10:33 PM
Jet-Jock's Avatar
Jet-Jock
Ok, electrically assisted variable effort system. Hmm registered trademarked MAGNASTEER® is the system. The EBCM controls a bi-directional magnetic rotary solenoid located on the steering gear. The solenoid adjust the amount of assist in order to achieve a given level of driver effort to turn by varying the current flow through the solenoid. . VES variable effort steering uses inputs from the ABS wheel speed sensors and steering wheel position sensor to the EBCM to determine how much effort is needed.
FSM reference Variable Effort Steering. The electromagnetic actuator which is the heart of the system, is known as VES Actuator. It consists of a mulitple pole ring style permanent magnet a pole piece and a electromagnetic coil assembly.
One requires a scan tool to perform the tests and bleed the system.
Old Apr 25, 2011 | 10:35 PM
seoulbrooks's Avatar
seoulbrooks
C5 = Magnasteer - http://forums.corvetteforum.com/c5-t...teer-help.html
Old Apr 25, 2011 | 10:48 PM
Jet-Jock's Avatar
Jet-Jock
My bad shouldn't have gone from memory. Yes it is as you described.
BTW it is suppose to move back and forth while operating. It should be free of movement and no binding.
Make sure the grooves of the belt are clean and not collecting material.
Old Apr 25, 2011 | 11:38 PM
Oh 2 Fun's Avatar
Oh 2 Fun
There ya go!! Good job....thanks,...that clears that up....but I still think it's more a problem with this than overheating etc.
Thanks again. Now I know.
Old Apr 26, 2011 | 01:21 AM
  #33
alankb's Avatar
alankb
well, did you try turning off the active handling and stuff?
Old Apr 26, 2011 | 01:26 AM
  #34
alankb's Avatar
alankb
Don't always assume the worst!!
