need mechanic help
So what am I looking at? Talked to two mechanics today, got two different answers. Am I worried over nothing? Or am I looking at the pump, or rack and pinion going out. Thanks for any help or advice you can give.
Sounds to me like a pump getting hot. I'd check that out.
I don't know for sure and I'm very new to the Vette scene, but I have owned several off road rigs (rock Crawlers), and have some experience in the steering field. A rock crawler will kill PS pumps faster than anything. I have some questions that may help me or someone else determin your solution.
1.) Have you had any service lately to the steering system?
2.) After running the car hard in the twisty's the pump should be warm, but only to about 170-180. Is it smoking hot to the touch?
3.) I am assuming you are not low on fluid, but what does it look like after a hard run? Foamy, frothy?
4.) Is the noticably louder after a hard run?
5.) Are any of the lines pinched or damaged?
It could be several causes to this, but the pump is very delicate when it comes to excessive heat. I have been through my fair share on other HP vehicles and almost always run a cooler to help disapate the heat. They are cheap and worth thier weight in gold if you ask me. Coolers and the best fluid money can buy for the pump your running are a priority for me.
Answer these, and maybe me or someone else will chime in, and try to help you out.
Reb
Luck,
John
4.) Is the noticeably louder after a hard run?
It could be several causes to this, but the pump is very delicate when it comes to excessive heat. I have been through my fair share on other HP vehicles and almost always run a cooler to help dissipate the heat. They are cheap and worth their weight in gold if you ask me. Coolers and the best fluid money can buy for the pump your running are a priority for me.
2 & 3. I will have to check for heat and if it is foamy or frothy on the next run. As far as being low it is about half way between the full and low mark. I will fill it before the next run.
4. no, there is no noise from it that I can hear.
5. All the lines look OK.
Luck,
John
Had exactly what you've described in my chevy pickup and it was the "EVO" sensor (electronic variable orifice) that controls how much boost your steering will get based upon speed and other inputs.
I ASSume the Corvette's sensor does much the same.
any codes?
That is probably your problem like most others suggested, the power steering system is overheating because of the stress your putting on it from driving the "curves" and causing the fluid to boil or close.
Like the others have said, check the complete system out, belts, fluid, sensors; also next time that happens stop and check the steering fluid to see what state it is in. Remember you can check it while hot.
