passenger side AC not working
Old Apr 21, 2011 | 09:27 AM
bphein80's Avatar
bphein80
Default passenger side AC not working
Just noticed the other day (generally dont have a passenger ) that the AC on the passenger side was not blowing cold. It was blowing, but at what appeared to be "room" temperature.
Any idea on possible causes? What would be the simplest to look at first. Thanks!
Old Apr 21, 2011 | 09:46 AM
Oldvetter's Avatar
Oldvetter
Do you have the digital, bi-temperature version? If so, your HVAC "doors" need to be re-synched.
Try:
http://forums.corvetteforum.com/c5-t...actuators.html
Old Apr 21, 2011 | 09:47 AM
tracer1's Avatar
tracer1
This procedure works with the dual AC (digital). With engine off, Pull the #27 fuse from the pass. floor fuse box. There is another HVAC fuse, but that one does not have to be pulled, just the #27. Wait 1 minute at least, not 58/59 seconds, reinstall. Should work OK. You may have to do this several times. Some say it will work also with the ignition key in the start position. The fuse has to be out this length of time for the computer to recycle. Also, on the driver side temp ****, don't adjust thie temp very fast, turn it gradually to allow the computer to keep up. Turning it too fast will get the computer out of sync. Also, always check your codes in the DIC. Hope this helps.
Gregg
Old Apr 21, 2011 | 12:38 PM
bphein80's Avatar
bphein80
Thank you both. I will try the suggestions this weekend.
To passenger side AC not working
