underhood insulation removed?
Old Apr 21, 2011 | 11:53 AM
c5sean85's Avatar
c5sean85
Default underhood insulation removed?
i have seen some vettes with the padding underneath the hood removed they either painted something on it or painted it smooth and i kind of like the look.. is there a major purpose for the padding? i pulled it back and looked with a flashlight it looks like its painted the same as the rest of the car....
Old Apr 21, 2011 | 12:36 PM
bumble-z's Avatar
bumble-z
I believe, It's purpose is a fire blanket. GM manual calls it "hood insulator"
Many have pulled their's off & painted murals,etc.
After market hoods come w/out the blankets.
It's just your individual preference.
Old Apr 21, 2011 | 12:38 PM
AngryTurtle's Avatar
AngryTurtle
I believe it is primarily noise, not fire suppression.
Old Apr 21, 2011 | 12:48 PM
hernandez3674's Avatar
hernandez3674
I dont mean to hijack this thread, but i also seen the corvette logo painted. Does anybody have a procedure how to do this. What paint is best to use. I;d like to try.
Old Apr 21, 2011 | 12:51 PM
I ran my Motor City Mold hood without an insulating blanket for over 5 years - never a problem.
Old Apr 21, 2011 | 12:57 PM
killain's Avatar
killain
Oldtimer
Default Underhood blanket ?
It mainly to keep the noise down , but it's also saves your paint on your hood from frying itself to till it's gone. I've seen some Vettes with out it but their hood paint is most likely going have a early death !
Old Apr 21, 2011 | 01:12 PM
c5sean85's Avatar
c5sean85
Is it painted fullly under the padding?
Old Apr 21, 2011 | 01:15 PM
dankhts's Avatar
dankhts
not always - usually some bare/thinly painted areas under the insulation
Old Apr 21, 2011 | 01:18 PM
hotwheels57's Avatar
hotwheels57
In days of potential carburetor fires, the hood insulator may have had something to do with smothering a fire.
In all of my cars since '65 with carburetor fires, it burned through easily because they tend to get contaminated with grease and other engine compartment contaminants. They were often made of horse hair. So I doubt the hood insulator ever had anything to do with fire suppression. More than likely it was to aid in reducing carburetor backfire damage to the hood/paint.
The hood insulator purpose (now) is to reduce engine compartment noise into the cabin.
Modern hotter running engine compartment heat may harm the thin base coat/clear coat paint paint w/o the hood insulator.
If you chose to do this, you may need to finish the underneath better with more clear coat to make it look more presentable if car shows are your goal.
Old Apr 21, 2011 | 01:34 PM
rdline's Avatar
rdline
noise and meant to melt the plastic clips and cover engine in event of fire. I have a painted underhood and have not had more noise or heat and the look is clean and great for shows as well. I have many friends that have removed the liner and no regrets either
Old Apr 21, 2011 | 01:42 PM
sfc rick's Avatar
sfc rick
If you don't have the money to have a professional do a airbrush job, do it yourself. I don't have money to spend like that so I took mine off and cleaned it gently. Then used a can of flat black spray paint, let dry. Came back and used Matte clearcoat, let dry. Then taped it up and that took most of my time so patience is required. Used regular automotive paint and brushed it on several coats. Looks great to me. Fancy it ain't.
Old Apr 21, 2011 | 11:48 PM
jdot's Avatar
jdot
My original hood insulator was worn, dirty and ugly. I bought a new one and painted the logo Vette colors and it looks great. Too each his own opinion though.
To underhood insulation removed?
