Overheating Problems
Old Apr 25, 2011 | 01:25 PM
mason071993's Avatar
mason071993
1st Gear
Default Overheating Problems
My 99 Vette (ls1) is overheating and the fans are not coming on. I checked the relays and they are good. I ran a wire from the battery to the fan motor and the fans came on. Does anybody have an idea on what might be the problem? Let me know, Thanks
Old Apr 25, 2011 | 03:22 PM
Paul 75 L82's Avatar
Paul 75 L82
Probally your rad and your A/C condenser is plugged up. Common problem this time of year. Blow it out with compressed air and see how much junk you get out. Sometimes a water hose will work also.
Old Apr 25, 2011 | 04:05 PM
UM Rebel's Avatar
UM Rebel
How hot is it getting? With A/C off, fans don't come on until over 225 degrees.
Old Apr 25, 2011 | 04:35 PM
robert miller's Avatar
robert miller
Most of the times never seen the fans go bad here but the fuse blow for what ever reason yes. Robert
Old Apr 25, 2011 | 04:41 PM
AU N EGL's Avatar
AU N EGL
Clean out the radiator then flush the radiator and refill
Old Apr 25, 2011 | 05:42 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Also check the fan grounds. They come together at a single point...ground pack at the right forward frame rail on top, next to the hood riser.
To Overheating Problems
