Piston slap sounds like rattling a coffee can full of marbles and is common on engines like ours that have a short-skirt piston design. This is a "typical" long-skirt piston:
And here is a short-skirt style piston:
Notice on the first piston that there is a long "skirt" extending well below the piston pin - unlike the second picture. The longer skirts produce more drag and friction in the engine, which is part of the reason they don't use them in our engines.
The "slap" is the sound of the piston skirts hitting the cylinders walls as thrust direction changes. You only hear it when the eninge is cold because the pistons heat up as the engine gets hot, the clearance betweem the pistons and the cylinder walls reduces and the sound becimes inaudible.
As many of these engines as we've seen go 250K miles and more, I doubt it's anything to worry about. It may sound disconcerting, but it's just the nature of the beast.
Thanks for the explanation mcm95403! This slapping seems to me like it would either damage the cylinder walls leaving minor dings, or leave marks on the side skirts, is that idea flawed? Or are the metals so hardened due to the immense heating and cooling that the minor "slapping" that occurs is "childs play" so to speak, meaning that no damage is done internally.
Mine started at about 50K or so and I have been assured by more than one Chevy tech that this is normal and will have no effect on reliabilty or longevity. I find it worse during the colder months and almost a non issue during the warmer months. When it is present all I do is let the car idle for about 1-2 minutes before putting it into gear and the noise is gone. You can only hear it when you first start the car cold and just drive without letting it warm up a bit and even then the noise disappears after about driving for about 15-30 seconds. I now have 74K on the clock and the car runs great, THANK GOD!
Yeah, it sounds like it sould take the engine out in a couple of weeks, but as you can tell from other posts, it's really not an issue. Pistons are an aluminum alloy with oil between them and the cast-iron cylinder bore liners. Remember that old saying "wears like iron"?
if my engine is cold I get it. Sicne they put it in the owners manual, I would say that the majority of them have it. Sounds like a knock until it warms up.
I'm not sure I ever did not heard 'Piston Slap" in a LSX engine that I can remember. The piston skirts are silicone coated it's really not a issue to worry about.
FWIW: at the Porsche-forum. they have piston slap in their engines as well ! Misery loves company.
I have 3 C5s, a 2000 A4, a 2001 A4 and a 2001 MN-6. All 3 slap when cold. Its annoying but I try to ignore it. I trust the guys on here are right that its not something to get concerned about.
