I found a c5 with low miles that is extremely clean the problem is it has piston slap when the engine is cold it sounds like a desil, once the engine warms up it is completely gone would most walk away or still consider buying ? I have read this is very common with the ls1 . This car is clean as a whistle 35k miles looks showroom new
My 2000 does the same..has 43K miles....doesnt use any oil.....everyone I have talked to that has an LS1 says the slap has not caused any problems other than the noise it makes for a couple minutes when started cold..
Well my thought is what happens when you decide to sell this car with the piston slap...its gonna scare away alot of potential buyers.(it would scare me off!) For this reason alone I would pass. On the topic of piston slap it is common but by no means acceptable. Find another or knock off $5G's for a fix down the road. ( My2 cents), Rob
Some have this in them try and get a good buy on it and if so go with it.
I bought an SS camaro and when I test drove it, it was warm because I met the guy half way. After buying the car it was a bit of a surprise the first time I started it up. I was pissed because the guy didn't mention it, but after doing some research it is a pretty common issue. I never really felt right about selling it so I traded it in. Now its the first thing I listen for, lol. I guess for me it was more the issue when selling it and explaining it to people. Now I have a cammed c5 and the valve train is noisy and I've just decided to get over it!!!
There's really no great way to deal with piston slap. A lot of guys here can guide you through using a can of sea-foam in an effort to remove the carbon build-up. But way back when these corvettes were built, the pistons were silicon coated just in case the engine developed "piston Slap. It really isn't a big deal so long as the ticking noise doesn't bother you. Personally I can't remember if I ever heard a LSX that didn't have piston slap to some degree !
I am the original owner of a 2002 with 74K on the clock. The piston slap started a few years ago and was told by more than one Chevy tech that this is normal for LS1 motors and poses no harm to reliabilty or longevity. The ticking noise is worse during the colder months than in the summer time. I let my car idle for about a minute or two before putting it in gear and the noise dissapears. If I'm in a rush then the noise will go away after driving for 15-30 seconds. I maintain my car very well and have it checked over thoroughly at every service interval and the car is solid, no leaks and does not burn any oil. If you can find a C5 without the piston slap then great, I think you'll find most of them will have it and as long as the car checks out after an inspection then I wouldnt worry about it. I speak from personal experience, but you do what your comfortable with and good luck with whatever you decide!
would everyone agree piston slap kinda makes the engine sound like a deisal ? the noise isnt really a ticking sound but it does go away completely as soon as the engine warms up.
yes, it is more than a 'ticking' sound. i had a 98 ls1 f-body that had it [124k when i sold it]. a co-worker bought a new 02 camaro ss that had it right off the showroom floor. when i bought this c5 there were 2 identical cars side by side. one with 88k miles, one with 20k miles, and they both had it.
it is what it is.
