I"m looking for the drivers side headlight insulators
Old May 3, 2011 | 08:04 PM
Loverofcorvettes's Avatar
Loverofcorvettes
Default I"m looking for the drivers side headlight insulators
I think the part number is 16524060. Dealer says they are discontinued. Anyone know where I can pick up a set, thanks.
Old May 3, 2011 | 08:13 PM
ColeTrain'sC5's Avatar
ColeTrain'sC5
are you talking the plastic surround piece that's held in with 3 screws? If so go to Corvette Central.com and they have replacements
Old May 3, 2011 | 08:45 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Not really sure what you are looking for, Is it the little black plastic pieces that the ball from the headlight goes into?
Old May 3, 2011 | 10:34 PM
rickko's Avatar
rickko
Contact Corvette Recycling in Utah. They are a USED PARTS forum vendor. Look near the bottom of the vendor list. Excellent people to do business with.
..rickko..
Old May 3, 2011 | 11:52 PM
Loverofcorvettes
They are on each of the mounting brackets travel stop tabs. Does I think I also need to add washers that go around the three bolts. Does anyone know the size, 10mm ??? I will try the Corvette recycler in utah, and Corvette central. Thanks for the help guys, this is a awesome resource.
Old May 4, 2011 | 12:14 AM
Jistari's Avatar
Jistari
Ya, the white plastic bump stops that fit on the tabs (two on top and two down below on the headlight motor stops) are (from what Ive read) discontinued. Best bet would be salvage I guess.
What you can do in the interim is cut a few pieces of 3/4 inch gas line (rubber) or even similar sized harder plastic tubing into about half inch lengths and slip them over the tabs.
Good luck
Old May 5, 2011 | 09:50 PM
Tigershark3's Avatar
Tigershark3
Good luck
That's what I did after one of them popped off. Not stock but ok for now.
To I"m looking for the drivers side headlight insulators
