Transmission cooler install
Old May 3, 2011 | 11:47 PM
95TAMaddog's Avatar
95TAMaddog
Default Transmission cooler install
I am going to buy a B&M cooler with fan and was planning on installing under the headlight on passenger side in the air duct for the front break. I am not sure how I am going to mount it. I was wonder if anyone has done this install and if they have pics of it. I am also wondering where to wire the fan into. Thanks in advance. I have a 1998 corvette A4.
Old May 3, 2011 | 11:50 PM
02*C5's Avatar
02*C5
Actually here is a good idea. Do 2 one behind the "Corvette" front plate on the bumper and the one on the condenser. That will keep it very nice and cool and you won't be taking any air from your breaks.
Do a mesh cover and no one will be the wiser.
Old May 4, 2011 | 02:43 AM
95TAMaddog's Avatar
95TAMaddog
Are you saying not get the one with the fan and just run two normal ones? Thanks
Old May 4, 2011 | 08:48 AM
02*C5's Avatar
02*C5
yup, the fan, while good in stop and go traffic, or at stop lights it hinders the flow of air when running on the highway. Remember the fan actually takes away about 10% of surface area when installed on top of the cooler.
What you are doing with the two is you get the front air, fresh air, running through the one in the bumper, starts the cooling process, then the already cooled tranny liquid goes to the second cooler where its cooled even more by one of two ways. Air coming up into the engine bay, or if you have the air conditioning on, the fans are forcing air to flow through the cooler. Either way its a very good set up.
good luck.
Old Sep 18, 2012 | 02:02 PM
sean.b's Avatar
sean.b
ok so im performing thread necromancy by bringing this back up, but is that last post a good idea? would that create too much of a pressure drop?
Old Sep 18, 2012 | 02:57 PM
NukeC5's Avatar
NukeC5
I have a thread up about this right now too. I haven't heard of doing it that way, but it sounds legit. I have a B&M fanned cooler in my garage right now and am trying to figure out the best way to mount it and hook it up. It is the fan recommended by RPM transmission, so I don't think I will go wrong with it, but this would be interesting to hear more about. And I might learn some thing about my install as this goes along.
Old Sep 18, 2012 | 03:06 PM
sean.b's Avatar
sean.b
arent you the one that had the paint-the-brake how to?
which cooler is it that RPM recommended? cus i have the RPM stage 5..
Old Sep 18, 2012 | 03:29 PM
NukeC5's Avatar
NukeC5
No, I don't have a brake paint how too... but the part number for the cooler is 70297. Its a B&M with an electric fan.
Old Sep 18, 2012 | 04:36 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
There is no need for a trans fan unless you visit the track often.
Just get a standard trans cooler and mount it in between the radiator and condenser near the bottom. When you are driving the front air dam will provide more than enough cooling to the cooler.
I have a single cooler mounted as stated above with a 3200 stall and my temps never go above 200 on the hottest days, normal is 180!
Also do not use the factory trans cooler in the radiator as the trans temps will be almost the same as your coolant temps. Keep them separated as to keep the trans fluid as cool as possible
Old Sep 18, 2012 | 04:40 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Single cooler is plenty to do the job and the fan models are for remote locations like in the rear of the car or mounted sideways!
2 coolers will do more harm than good!
Old Sep 18, 2012 | 04:48 PM
NukeC5's Avatar
NukeC5
I used to always think running only the aftermarket cooler was fine. I hooked it up like that in my old trans. But the guy at the shop I go to made a very simple yet effective explanation of how the trans cooler works.
Basically he did a demonstration of how much faster a red hot piece of metal cools down in boiling hot water than from a high powered fan. He made the point that you should never take away a liquid cooling system for an air cooled one. Both in conjunction will work best as the aftermarket cooler will give an extra bit of cooling.
Anyway, I cant explain it as well. But it was his 30+ years of experience as a transmission tech and performance enthusiast that made me think, wow, that is very true. No matter how hot the radiator cooler gets, its still passing the heat off through a liquid system. Much more effective than air alone.
That being said. I think people can have it work either way. After all people are successful at both obviously. But I will be hooking up both coolers in series as was recommended by an expert.
Old Sep 18, 2012 | 05:11 PM
sean.b's Avatar
sean.b
heat is heat, this isnt rocket science if trans temps are above coolant temps (usually are) then it stands to reason there's room to be made by running it through the radiator THEN the stand alone. im going to try that first, and failing that, ill run it stand alone with a fan.
Old Sep 18, 2012 | 05:16 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
In this situation, if your cars coolant is 210-220 on a hot day, Your trans temps will be close to 210 as the trans fluid is flowing through a hot radiator.
If you separate these two, you will see much cooler trans temps! I have done it both ways and the separate trans cooler dropped to 180-190 while the coolant was 210-220! To each his own I guess, just sharing what works the best for me!
Old Sep 18, 2012 | 05:20 PM
sean.b's Avatar
sean.b
having read ~12 or so threads on this on these forums, the consensus WAS that the stand alone was cooler... i think the radiator is heating it up compared to what it would otherwise be for most of us.
Old Sep 18, 2012 | 05:23 PM
NukeC5's Avatar
NukeC5
Both ways seem good. I really cant say whats the best. I think I will try it through both and see how it works before going to just the aftermarket. If its too hot I will go to the aftermarket only.
Old Sep 19, 2012 | 01:21 PM
mustangracer's Avatar
mustangracer
This was one of the first things I did when I got my C5, my temps before were usually 190+ sometimes 220 just normal driving. I got the B&M 70266 without a fan and bypassed the radiator completely, then mounted in front of the condenser. I dropped my temps drastically, on cold days im about 156* and in traffic during summer 180* with a 3600 stall.
To make the lines going from the 1/2" pipe to braided line I first cut the hard line and got some 1/2" to -6 fittings. To do this you have to flare the ends and this was a bitch because theres very little space and not much line to flare because of all the bends but it is do-able. After that point on is a cake walk and you'll need some -6 90* hose ends and -6 straight hose ends. I dont like cheap rubber line or having to replace something more than once so I did it right the first time. I can post some pics up later tonight as Im about to go fix the exhaust on the vette now.
Old Sep 19, 2012 | 01:54 PM
Aerovette's Avatar
Aerovette
I cannot find it now, and I will keep looking, but I know I read that there is a minimum temperature for an automatic transmission as well as a maximum. According to what I read, keeping it too cool will also cause damage. Not sure how until I find the reference again.
To Transmission cooler install
Old Sep 19, 2012 | 01:59 PM
NukeC5's Avatar
NukeC5
Yes 156 is too cool. A transmission should be around 170 to 180 degrees as an optimal temp. I will hook up my fanned cooler to try and maintain 175ish. But less than 170 is supposedly not good for the wear of components inside.
Old Sep 19, 2012 | 04:51 PM
mustangracer
I should say that is very rare that it sees that low for two reasons. One being that I hardly drive the car during cold months, and two I drive the car HARD most of the time so the trans is warmer than 150's most of the time. Ive had this setup for over two years now and havent had any problems with the trans and its completely stock *knock on wood*
Old Sep 19, 2012 | 05:35 PM
NukeC5's Avatar
NukeC5
For anyone reading this, I just got off the phone with B&M and they said you can run it through the radiator or the cooler itself. It really wont make a difference. If it goes through the radiator, then the cooler, its still going to get as cool as the cooler on its own. The radiator way is better in cold climates where it can help the transmission heat up and regulate temps easier.
