Options
Old May 4, 2011 | 08:14 AM
barblarry93's Avatar
barblarry93
Default Options
Is it possible to see what gear ratio my 2000 Conv. 6mt has by looking at the option codes posted in the glove box? It seems much higher geared than my 2003 Coupe Auto.
Old May 4, 2011 | 08:30 AM
ljthe2nd's Avatar
ljthe2nd
All 6 speed C5's came with a 3:42 rear end. Cars that came with an auto trans came standard with a 2:73 rear. An optional 3:15 was available for auto's, and that will be listed on the glove box.
Look on glove box, and then look here for RPO codes (regular production options) to decipher those codes.
http://www.corvetteactioncenter.com/specs/
Old May 4, 2011 | 08:51 AM
barblarry93
Thanks. Maybe the 6mt is low on power. The a4 would spin its tires with gas to the floor. 6mt just takes off. Same tires.
Old May 4, 2011 | 09:20 AM
steve8's Avatar
steve8
Have you turned off your TC?
Old May 4, 2011 | 09:28 AM
barblarry93
I no longer have the A4 but the TC was on with both cars.
Old May 4, 2011 | 10:57 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
On your MN6 car - 4th gear @ 70mph, your RPM's /1000 will come pretty close to your gear ratio.
In other words - 3420 rpm @ 70mph would be a 3.42 ratio. 4th gear is 1:1.
Also - on the RPO sticker on the glove box door you should see option code GU6 for the 3.42 gear set.
Here's a handy listing of C5 RPO codes and their meanings.... click here!
To Options
