B1001 Code
Old May 5, 2011 | 11:53 AM
Tigershark3's Avatar
Tigershark3
Default B1001 Code
I've got it as a current code and the airbag light is on so I'm guessing that the airbag deployment is disabled. I clear the code and it comes right back. DTC only gives me the code so is there a way to determine if the SDM is defective or one of the sensors? Tech II?
Thanks in advance
Old May 5, 2011 | 12:23 PM
87SAM's Avatar
87SAM
The code means the restraints ID in the SDM does not match what is stored in the BCM.
Old May 5, 2011 | 09:43 PM
Tigershark3
I got that but w/o the right equipment I can't tell where the fault is. Dealer says that for $80 they will diagnose the problem and tell me what needs fixing... SDM is almost $500
Old May 6, 2011 | 07:18 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Let them do the diagnostic as its worth that. Then if it is the SDM, you can send it out for repair for a lot less.
To B1001 Code
