Can I Do This?
Old May 5, 2011 | 10:13 PM
tony123's Avatar
tony123
Default Can I Do This?
Lets say, I'm about to change my PCM. My Corvette is a '98. Can I use any other PCM module besides the '97-'98. For example, the '99, '00, '01...? Has anyone tried something like that without rewiring?
Thanks,
Tony
Old May 5, 2011 | 10:51 PM
Carcass's Avatar
Carcass
It can be done,but it involves a "little" rewiring:
http://www.efialchemy.com/techdb/02to97pcm.html
There's a thread on the forum with more detail,but I couldn't find it-
Old May 5, 2011 | 10:53 PM
rtpassini's Avatar
rtpassini
St. Jude Donor '11-'12
i believe in the DIY sticky in the tech forum. theres a part that says how to use a 00 and up in a 97-99 (or something close)
Old May 6, 2011 | 01:27 AM
tony123's Avatar
tony123
Originally Posted by 8VETTE7
A little rewiring???? Here's a cut and past from the article you linked to:
The basic idea of performing this swap involves removing all 300-320 wires from the PCM connectors, and remapping them into the correct positions for the '02 PCM
I guess that is a LITTLE rewiring..........
Old May 6, 2011 | 01:47 AM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Reading the whole article, it looks a little time consuming but actually pretty easy. Probably a one day job. I might give this a shot next winter.
Old May 6, 2011 | 01:49 AM
doje's Avatar
doje
http://forums.corvetteforum.com/c5-t...-corvette.html
Old May 6, 2011 | 01:59 AM
tony123's Avatar
tony123
hmmm a day... goodluck
Old May 6, 2011 | 02:08 AM
doje's Avatar
doje
Well, if you read the link I posted, the OP says with two people it will take "the better part of an afternoon". As an electrician I think I am competent enough at IDing wires, following schematics, and trouble shooting if needed. A day with a buddy and a 12 pack should be just fine.
Old May 6, 2011 | 02:48 AM
209TIME!!!'s Avatar
209TIME!!!
whats the point of putting a newer PCM in a older model car???
Old May 6, 2011 | 02:58 AM
doje's Avatar
doje
If you are doing major horsepower mods, the newer PCM is much better at handling the rapid data required. It's like comparing a new computer to an Apple IIe.
Old May 8, 2011 | 02:22 AM
tony123's Avatar
tony123
"whats the point of putting a newer PCM...." ..... hmmmmm Ebay,
$300-98......, 80 > 120-2000...2002...04. lol, what about that.
Old May 8, 2011 | 07:25 AM
Carcass's Avatar
Carcass
RockAuto has remanufactured early PCM's for $109-$197,the later model PCM is $98-$181
I'll spend the extra $16,(if the need arises)but I have no major engine mods...
It pays to shop around a little...
Old May 8, 2011 | 04:30 PM
Blow Torch's Avatar
Blow Torch
Yep; I found one from a forum member for $75, and a couple more for around $100
And by the way, you can make quite a bit of hp with a 98 pcm (ask me how I know )
IF, it was a straight swap, I would have went ahead and changed to a newer one, but for the trouble, AND the fact that I'm SD tuned, it was no benifit to me
Old May 8, 2011 | 06:07 PM
tony123's Avatar
tony123
Hmmmm... I recognized a ninja in you tell my litle bit more about that please, and who seling that PSM, and what you think what is the best for me(how to do it ) THANKS///
To Can I Do This?
