gas milage
stock except intake and exhaust.41 k running toyo proxies. 17x8.5 front and 18x9.5 rear.I am a light footed driver.
I get maybe 17 city. (Heavy Foot) on the road with cc on I get about 29mpg.
Lots of factors go into gas mileage, having an A4 gets you worse MPG than M6, and then it depends if you do a lot of in town driving.
I get about 15mpg in town and high 20s highway.
Try resetting your Avg. MPG on the display at every new tank to get a more accurate reading.
Are you using premium fuel?
Try a bottle of Techron fuel additive.
Does your air filter need cleaning?
Is it time for an an oil change?
Are your tires properly inflated and balanced?
Don't forget to clean the modular spindulator by pulling the pull string behind the progressive fuel dialator.
Thank you
Fred
Thank you
Fred
!! Now it is amazing just how little romping really knocks the crap out of your mileage,,so that too may be a factor. It is just soo easy,,and fun to just give it a little romp here and then,,and there goes the average
!! Again,,check those plugs,,you will probably be surprised how out of wack they are!!
The RPO code codes are
GU2 for the 2.73
G90 for the 3.15
The list of build codes for my car are in the glove compartment.
Just a suggestion.
