[Z06] englandgreen does it again
Old May 28, 2011 | 03:56 PM
hdff's Avatar
hdff
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
i did it mainly for the sound and the shake and man i got both.... stephen did a great job. i contemplated for a while before i did it now i am kicking myself in the a$$ for waiting so long.......
Old Jun 2, 2011 | 06:51 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Sweet
Stephen
Old Jun 14, 2011 | 08:48 AM
nullpointer's Avatar
nullpointer
How is the cam with stock 3.42 gears? Do you need gears ?
Old Jun 14, 2011 | 02:26 PM
ClaytonPowell's Avatar
ClaytonPowell
from what i've seen so far it could very easily be a dd. can't cruise in 4th going 40 now and takes a little more pedal when letting out the clutch but drives great
Wait, what? You can't cruise at 40mph in 4th? When I'm slowly putting around I'll be in 6th at 35mph. Am I hurting my car by doing this (car sounds strong at this speed, although anything less and it starts to shutter a little). If I go with a cam will I not be able to do this?
Old Jun 14, 2011 | 10:04 PM
hdff's Avatar
hdff
no i don't think so, low rpm's lug the motor and it doesn't like that, stephen can probably explain it better.
Old Jun 17, 2011 | 06:27 AM
99MALLETT396's Avatar
99MALLETT396
I am not trying to be rude, but why are you insisting to cruise in 6th at 35mph? Allot of guys to you that's it's not good for the motor to do so, I've even seen it in your post asking for the same thing. I will tell you here again it's not good to lug your motor.
Sorry for the hijack.
