remote range
Old May 11, 2011 | 04:47 PM
mcgilles's Avatar
mcgilles
Default remote range
My factory remote seems to have an effective range of about 1.5m. I don't think it was like that when I bought it just went down over the years. Its got a good battery I already checked. I'm assuming that's not typical. Is there anything I can do or should I just replace the remote?
Old May 11, 2011 | 04:53 PM
k0ts's Avatar
k0ts
I just bought a new FOB and it's range is maybe 10-15m or so.. Much better than the old one when it was working.
Old May 11, 2011 | 05:06 PM
jrose7004's Avatar
jrose7004
Sometimes mine works from 100 feet sometimes 2 feet.
Old May 11, 2011 | 05:56 PM
SaberD's Avatar
SaberD
i bought a new fob a couple years ago, and it has always worked from around 3m (9ft) away. it doesnt bother me as long as i dont have to put the key in the door and risk scratching it.
Old May 11, 2011 | 08:16 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
i've never had mine work from 100 feet, but i would say it works consistantly from approximately30 ft or a bit more. i have found in areas where i suspect there is a lot of RF interference like from alarm system in shops and banks, etc the range is greatly reduced sometimes down to right at the front fender. there are some tricks you can play with any car remote fob like pressing it to a car antenna when you hit the button. it seems to extend the signal strength.
Old May 11, 2011 | 08:40 PM
seoulbrooks's Avatar
seoulbrooks
I agree. The surrounding environment seems to be a big factor in FOB operation. When home I easily have FOB operation from 30 - 40 ft (have not tried from a greater distance), but when in the work parking lot I have to be right up against the car. Since these are very small powered transmitters the surrounding interference plays a big role in their operation.
Old May 11, 2011 | 09:44 PM
mcgilles's Avatar
mcgilles
Originally Posted by 8VETTE7
Your profile says you own a 99 which would mean your remote has the legendary PASSIVE mode. If your using that mode, turn it off and see what it does. Also many of the early remotes eventually suffered from loose internal components. Look through this post and then check out your remote for the problems described:
http://forums.corvetteforum.com/c5-t...post1570747451
thanks! I actually saw that once before and already applied the suggested fix to all the pins on the IC. it didn't seem to change anything.
I guess that's just the way it is, but I'm sure a new remote would improve things some. I have an aftermarket alarm which has no problem working from very long distances. only thing I want the stock one for is for the windows with the valet. today I had to walk out into the rain to put the windows up. just drizzle so no big deal, but it would be nice to have it work from 40 ft away then I wouldn't have to get wet as it starts to rain.
Old May 11, 2011 | 10:14 PM
65GGvert's Avatar
65GGvert
I actually stepped off the range on my 98 and it was over 75 feet. Even farther if I place it against the underside of my chin and opened my mouth. I know, I laughed too, till I tried it and it extended the range. I tried it on my F150 and it also extended the range. Just sayin'
Old May 11, 2011 | 10:49 PM
mcgilles's Avatar
mcgilles
sounds like I should find the antenna leads and run a wire to them to a contact pad on the outside of the remote. then I can use my body to extend the antenna, remote in one hand and hold the other upwards to boost the range! haha.
another funny thing about the remotes range I've noticed. if I walk up to 3 ft from the car so it will start responding, I can then back off a good distance and it will still work. but not until I've gotten close first. kind of defeats the purpose.
Old May 11, 2011 | 10:54 PM
sfc rick's Avatar
sfc rick
And I always thought those were the people acting like guppies out of water on purpose! Now I know it's the secret key Fob trick!!!!!
Old May 11, 2011 | 11:08 PM
duramaxsky's Avatar
duramaxsky
I have 2 new fobs for my 98 and they are no where near the range of my other vehicles. I found my truck at Six Flags Magic Mountain from clear across the lot. I always forget where I park there for some reason. I have walked all over that lot with a rental car fob pushing the panic button a few times. At least I remember what my truck looks like and it taller than the cars. My Sky and Michelle's Malibu have much less range than the truck but much more than my C5. If the passive switch is on it seems to be less.
Old May 12, 2011 | 11:16 AM
Florida99's Avatar
Florida99
Lots of dental work no doubt
Old May 13, 2011 | 02:55 AM
Mr31FlavorsVette's Avatar
Mr31FlavorsVette
St. Jude Donor '12
That's funny, I learned that from my wife recently as we walked up to my car. I was complaining about how close I had to get for the remote to work. She took the FOB, walked about 9' away, put it under her chin and sure enough the damn thing worked. I couldn't believe it, so I tried it too. Hated to admit it, but she had one up on me.:o
My Ford Sporttrac's FOB would work 100' away, go figure. As sleek as our cars are, GM apparently didn't give much thought aboout the design of our FOB's, kinda fat, stubby things...imho.
Old May 13, 2011 | 09:23 AM
Carcass's Avatar
Carcass
Mine works 50-60 feet.
Odd thing-If I'm parked in front of the ATM machine where I make my bank deposit,It won't work at all unless I hold it about a foot from the left rear fender and press the button....everywhere else,it works fine.
Old May 13, 2011 | 02:07 PM
Mine works at at least a 30 foot range. Haven't tried it much further than that.
Old May 13, 2011 | 05:20 PM
markKlein's Avatar
markKlein
Wait, what? Your factory fob rolls your windows up?
(Still sounds like a weak battery, how exactly did you determine it is still strong?)
Old May 13, 2011 | 05:45 PM
mcgilles's Avatar
mcgilles
Yep. Thanks to the wonders of the window valet.
I tested the battery with a voltmeter. A few times. Still over 3v. But I also replaced it just to make sure. Figured it was worth a few bucks. Didn't change anything though.
To remote range
