Considering a Late Model C5
Old May 14, 2011 | 01:29 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Default Considering a Late Model C5
When I totaled my car, I originally wanted to upgrade to a C6, but I'm thinking that they're just not in the price range and I already have stuff for the C5.
I'd like to get the best of the LS1 setups and If I remember correctly it was between 02 and 03.
Also I'm not up to date on the subtle changes between 01 and 03 cars.
Any thoughts?
Old May 14, 2011 | 04:03 AM
momo20's Avatar
momo20
i would say do it...why not get a Z06?
Old May 14, 2011 | 08:07 AM
I'd get the newest one that fits in your budget. Here's a list of changes that were made to the C5 platform (this was posted on the forum a while back):
1997
• Completely new, redesigned Corvette. Base (FE1) and Z51 (FE3) suspension packages.
• All Z51 cars include: Power Steering Cooler
• 97-00 C5 LS1's produce 345 HP @ 5600 RPM and 350 Ft Lbs of torque @ 4400 RPM.
1998
• Convertible becomes available
• Active Handling becomes available late in year
1999
• 26# injectors substituted for 28#
• Fuel pump revised to reduce noise
• FRC "Fixed Roof Coupe" aka the hardtop, becomes available. All FRC's are MN6 (6-speed) cars with the Z51 suspension package, and are about 60lbs lighter than coupes.
• HUD introduced
• Only one line in driver's side fuel rail cover (no fuel return line?)
• Power telescoping wheel becomes an option
• Steering hardware changed to combat wandering
• Door sill trim plates added
2000
• Millennium Yellow available
• "Thin Spoke" versus "wagon wheel" design wheels become standard.
• Pup cats added to all models for LEV emissions requirements (5hp loss relative to 97-99)
• Steel swaybar endlinks instead of plastic on Z51 equipped cars
• Z51 swaybar diameters grow (25.4/21.7 to 28.6/21.7 to 28.6/23.6 (note: new rear same as Z06)
• No keyhole on passenger side doorhandle
• Passenger airbag 'off' switch added to console (light by TC/AH button) – mid-model year change.
2001
• Return to 28# injectors for all models.
• Second Generation Active Handling
• Nassau Blue discontinued
• Alternator 'clutch' pulley added on A4 cars
• New soundproofing + foam in all cars
• Smaller keyfob
• Electrochromic dimming rearview and driver's mirrors
• Lighter AGM battery
• Thickness + Material in Convertible change
• Chrome exhaust tips for coupe + Convertible
• 85MM MAF with integral temp sensor (versus 74mm with separate plug for IAT)
• LS1 cam profile changed to: .500/0.500, 198/208 on 115.5LSA (From: 0.472/0.479, 202/210 on 117)
• All Corvettes now have the LS6 intake manifold
• All Corvettes now have the LS6 engine block (windage passages in block), which includes a beefier oil pump.
• LS1 changes result in new output of 350 HP @ 5200 RPM and 375 Ft Lbs of torque @ 4400 RPM (MN6)
• Hardtop/FRC discontinued
• Stronger synchros in all transmissions
• Exhaust manifolds revised (5hp regained) - thin wall cast replacing SS manifolds
• Metal valvestem caps (late year)
• Torque Tube changed from metal-matrix composite to aluminum alloy 6061, increased in diameter from 55 to 63 mm.
• Driveshaft couplings have also been upgraded on manual-equipped models for additional strength and durability
• Introduction of the Z06, which has as differences:
• Hardtop body style
• Rear brake ducting
• Screened inlets on front fascia, without foglights
• F1 Supercar tires 265-17 front, 295-18 rear, on 17x9.5 and 18x10.5 (one inch wider, respectively
• New LS6 top-end with new style head design (10.5:1 compression, 64cc chamber), LS6 cam (0.525/0.525, 204/211 on 116) - 385hp
• M12 transmission with shorter gearing (1-2-3 analagous to MN6 with 3.90 rear diff
• Titanium exhaust system
• Lightweight windshield
• New, stronger clutch with redesigned master + slave cylinder
• Stronger rear differential (shotpeened ring gear)
• Red brake calipers (otherwise identical)
• Transmission overtemp warning light on DIC
• 6500 redline gauges with special checkering + Z06 font
• Redesigned PCV system to help combat oil burning
• Red LS6 Fuel Rail Covers (FRC's)
• FE4 Z06 suspension - uprated springs, bars (30mm/23.6mm), shocks (note front spring and rear bar same as Z51)
2002
• Z06 Changes:
• Z06 LS6 cam changed to: 0.551/0.547, 204/218 on 117.5
• Less restrictive intake airbox lid
• Descreened MAF
• Removal of pup-cats (total with changes = 405hp)
• Z06 shocks revised with less rebound for better launching
• Z06 brake pads revised for better stopping (generate more dust)
• Lighter, sodium filled valves w/ stronger valve springs
• Higher tension rings installed to prevent oil burning problems
• Slight piston redesign *
• Clutch strength upgraded.
• HUD available on Z06 (not avail '01 model year)
• Wheel supplier changed to Speedline, moved from forged to cast. Weight nearly identical
• Electron Blue color offered
• Steel endlinks changed to aluminum
2003
• Late model-year new fuel system design from C6's
* Magnetic Ride Shocks were introduced.
2004
• Z06 shocks further refined. Accompanying upper front control arm bushing, and rear swaybar bushing changes.
Old May 14, 2011 | 08:54 AM
jrose7004's Avatar
jrose7004
Old May 14, 2011 | 09:20 AM
TheRadioFlyer
Supporting Vendor
I live/drive in suburbia and driving a Manual car would get very tedious when there's stop lights every 500 feet. Plus i need the additional storage space and fuel economy of a Targa coupe.....F. or instance, I KNOW I can fit my full size mountain bike inside my 97, the same cant' be said for the FRCs
Old May 14, 2011 | 10:07 AM
flynbyu2's Avatar
flynbyu2
St. Jude Donor '10
I'd get an '03. All the important updates were made by then AND you get the super sexy 50th Anniversary badges.
Old May 14, 2011 | 01:11 PM
TheRadioFlyer
Supporting Vendor
Lol....i'm just gonna black out the flags anyway. I've heard some of some 03 cars having fuel system issues regarding the re-design. I'll have to look more into that.
Old May 14, 2011 | 01:42 PM
YeloFevr's Avatar
YeloFevr
No issues that I'm aware of other than you have to DROP THE TANK to get to the pump on '03+. '02 and previous have pumps that you can easily access from the LR wheel well. All comes down to what your plans are for the car.
Old May 14, 2011 | 03:07 PM
cor28vettes's Avatar
cor28vettes
Fuel issues w/certain 04's from a bad batch of parts is the latest, which are being made good by GM if there is an existing issue. Yes, redesign took place in Nov 02. All C6 have this new system.
Old May 15, 2011 | 01:29 AM
jornahow's Avatar
jornahow
My research led me to buy a 2002 A4 coupe. There were some engine improvements from 01 to 02. Some 01 cars had an excessive oil consumption problem. The 02s have the Z06 intake manifold and they do not have the problematic fuel tank system found in 04 and some 03s. I don't think there were any significant improvements after 02. My only problems have been ABS module failure fixed by ABSFIXER for $150 and dim HVAC display, easily fixed. Everything else I have spent is on improvements. Purchased in 2007 with 37,000 miles; now has 75,000. It has been my daily driver - one of the most enjoyable and trouble free cars I have owned.
Old May 15, 2011 | 04:26 PM
teebee's Avatar
teebee
2021 C6 of the Year Winner - Unmodified
All the 01's got the Z06 intake.....If memory serves me correctly.
Old May 15, 2011 | 07:49 PM
C5FORFUN2's Avatar
C5FORFUN2
Correct '01 & up have LS6 w/ LS1 heads and in between cam.
Old May 16, 2011 | 01:37 AM
TheRadioFlyer
Supporting Vendor
Yea, but the 241 heads beat the hell out of the 800 series.
I still can't believe I made as much power as I did with my stock 97 motor. The only internal modifications were 1.8 rockers and valve springs.
Old May 16, 2011 | 03:36 AM
cor28vettes
1997
1998
1999
• HUD introduced
2000
2001
• Smaller keyfob
2002
• Z06 Changes:
• Descreened MAF
2003
* RPO FFS introduced new fuel system design Nov 25, '02 w/VIN 14029
* RPO F55 Magnetic Ride Shocks replaced earlier F45
* RPO 1SC 50th Anniv 'Edition' 5K package; others had 50th emblems only
2004
* Commemorative Editions to honor success of C5R Racer
* Carbon fiber introduced on Z06 CE hood
* Z06 suspension revised to improve cornering control
* amended for 03/04 only
Old May 16, 2011 | 12:31 PM
TheRadioFlyer
Supporting Vendor
Was there any changes between the 01 and 02 NON-Z06?
Old May 16, 2011 | 02:02 PM
Rob04C5LM's Avatar
Rob04C5LM
Unless you care about the 50th or LeMans CEs, the 2001+ coupes are pretty much the same. I'd be more interested in the price/mileage/options value equation than the subtle differences in the 01+ cars.
I have noticed a few minor things that are different on my 2004 than on the 01-03s that aren't listed above (for example, I got a different style thermostat) but I'm sure none of it is terribly significant.
Can't wait to see what you do with it!
Old May 16, 2011 | 03:51 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I would get the newest Coupe you can afford and enjoy a new Vette
To Considering a Late Model C5
Old May 16, 2011 | 04:35 PM
RedSoxFan's Avatar
RedSoxFan
I would look for an early model '03, according to info that was posted in an old thread the problematic gas tank design was introduced in 2003 models with VIN 35111542 (beginning on assembly date Nov. 25, 2002). The problem I'm referring to is the leaking cross-over connector.
Old May 16, 2011 | 05:14 PM
cor28vettes
A/T trans cooler cases changed from SS to aluminum.
Front stabilizer links were changed from steel to aluminum. Initially intended for Z51 & Z06 but all 02's had them.
Verts with heads-up (& Z06) had thinner 4.8mm windshield. Others had 5.4mm
RPO N73 mag wheels weren't listed as optional, but were available at $1,500 in limited quantities (114). Floor mats were standard.
The usual drop/add color changes
source: Genuine Corvette Black Book
Old May 16, 2011 | 05:22 PM
max'svette's Avatar
max'svette
St. Jude Donor '11
An engine that doesn't burn oil.
