Getting window up WITHOUT door control switch?
Old May 14, 2011 | 10:47 AM
Superman09's Avatar
0Superman09
Former Vendor
Default Getting window up WITHOUT door control switch?
Well I recently sent my drivers side door control switch out and forgot to put my window up all the way, oops! Anyways I want to wash the car and drive it without having to make sure it cannot rain. Any way I can get the window up without the door switch? Thanks!
Old May 14, 2011 | 10:51 AM
JuicedZ's Avatar
JuicedZ
You don't have a window valet by any chance do you? I have one on my coupe and it's handy. Lock button on the fob three times will roll windows up.
Old May 14, 2011 | 10:55 AM
Superman09's Avatar
0Superman09
Former Vendor
I do not Plus my fob is not working as I have an electrical gremlin
Old May 14, 2011 | 11:12 AM
dndrsn's Avatar
dndrsn
Can you use a jumper wire to jump the connector.
Old May 14, 2011 | 11:17 AM
Kevin Kuse's Avatar
Kevin Kuse
I have wire diagram I can e-mail if you get me your address. I am only here till noon CST
Old May 14, 2011 | 12:42 PM
Superman09's Avatar
0Superman09
Former Vendor
Honestly a wiring diagram might be over my head. I could jump the connector but unsure which plugs to jumper together to get it to go up?
Old May 14, 2011 | 12:44 PM
Jistari's Avatar
Jistari
Use the switch from the other door?
Edit : by that I mean, take it out, connect to other side, close window, reinstall.
Old May 14, 2011 | 12:47 PM
Superman09's Avatar
0Superman09
Former Vendor
connectors are different on each side. Drivers side much larger to control memory and all that jazz. Good idea though, first thing I tried.
Old May 14, 2011 | 12:53 PM
Kevin Kuse's Avatar
Kevin Kuse
At the LH Door Switch.
LH Window up 12v (Brown), LH Down 12v (Grey)
RH Window up 12v (Lt.Blue), RH Down 12v (Tan)
Ground is Black.
Old May 14, 2011 | 01:00 PM
Superman09's Avatar
0Superman09
Former Vendor
Where are these, are the star connector? on passenger footwell?
And to get LH motor up, jumper brown to black?
Old May 14, 2011 | 06:21 PM
Superman09's Avatar
0Superman09
Former Vendor
Also, there is 3 lt. blue wires on the drivers door switch along with another lt.blue/white striped
Old May 14, 2011 | 08:59 PM
n8dogg's Avatar
n8dogg
just jump 12v to the motor connector. Or borrow someones switch real quick, it just pops out after all.
Old May 14, 2011 | 09:02 PM
Superman09's Avatar
0Superman09
Former Vendor
Got it up, lol..... window that is Thanks!
Old May 14, 2011 | 09:29 PM
dndrsn's Avatar
dndrsn
Well, how did you end up doing it?
Old May 15, 2011 | 11:14 AM
Superman09's Avatar
0Superman09
Former Vendor
Jumpered the brown (LH Window up) to the black (Ground) and key on and up she went
Old May 15, 2011 | 11:21 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Wow, That sounds strange, !2v to black ground and it worked...
Old May 15, 2011 | 01:39 PM
Superman09's Avatar
0Superman09
Former Vendor
you got it I am not too electrical savvy but this is all I did.
Old May 15, 2011 | 05:39 PM
Jistari's Avatar
Jistari
OMG
You do realize that that will aslo zero out the PCM (thus negating any aftermarket tune you may have had), and reset the security code in the radio to a random number and also probably switched the polarity in the headlight controller (up is now down, so you'll have to either drive with them up but off, or install mirrors and drive with them on but down).
Sorry.....couldnt resist.....
It was something that clicked in my head when Mr. Bill made the observation of how counterintuitive it seemed to connect 12V to black ground.
Really....forgive me . . .
Old May 16, 2011 | 08:38 AM
Superman09's Avatar
0Superman09
Former Vendor
lol, had me going for a second! Wouldn't be the first simple electrical thing I did that totally screwed up the whole car!
OMG
To Getting window up WITHOUT door control switch?
