Do I have to gap?
Old May 23, 2011 | 06:16 PM
snowbird12's Avatar
snowbird12
Default Do I have to gap?
I bought plugs from Gene Cully. Are they already gaped? If not what is the gap?
Old May 23, 2011 | 06:27 PM
Kevin Kuse's Avatar
Kevin Kuse
INFORMATION
Bulletin No.: 03-06-04-060B
Date: July 30 2008
Subject:
Information on New Spark Plugs and Gapping
Models
Attention: Please disregard the Set Gap Per Vehicle Specification statement on the side of an ACOelco(R) Iridium Spark Plug Box. The statement will be removed from the boxes in the future.
Supercede:
This bulletin is being revised to add the Chevrolet SSR and the 2005 Pontiac GTO. Please discard Corporate Bulletin Number 03-06-04-060A (Section 06 - Engine/Propulsion System).
^ A new spark plug has been released for use in the above vehicles. The new spark plug has an Iridium tip instead of the current Platinum tip. Due to the different tip design the gap of the spark plug has also changed.
^ The new spark plug P/N 12571164 with AC Delco P/N 41-985 is gapped to 1.01 mm (0.040 in) when the spark plug is made.
Notice: The spark plug gap is set during manufacturing and should not be changed or damage to the spark plug may result. Any new spark plug found to not be properly gapped should not be used.
Old May 23, 2011 | 06:30 PM
Jet-Jock's Avatar
Jet-Jock
Old May 23, 2011 | 06:41 PM
snowbird12's Avatar
snowbird12
The plugs I have are p/n 41-110 ac delco.
Old May 23, 2011 | 06:48 PM
Jet-Jock's Avatar
Jet-Jock
That's the Iridium plug. You're ready to go.
Work on a cold engine. Apply aluminum anti-seize to the plug threads and torque each to the proper spec. 15Nm (11 lb-ft). Use dielectric grease on the plug boots.
There's some good tips around the forum, driver's side is easiest by just removing the AIR valve, two 10mm bolts swings out of the way.
Old May 23, 2011 | 06:49 PM
ricknyc23's Avatar
ricknyc23
[QUOTE=Jet-Jock;1577691164]That's the Iridium plug. You're ready to go.
Old May 23, 2011 | 07:49 PM
The plugs should be pre-gapped. No need to change them.
To Do I have to gap?
