A/C belt replacement
Old May 24, 2011 | 12:04 AM
corvettedaddy11's Avatar
corvettedaddy11
Default A/C belt replacement
Changing out the A/C compressor in a few day's anyone know of a thread on how to take the a/c belt off before I start my work...!
Old May 24, 2011 | 01:23 AM
DeeGee's Avatar
DeeGee
The main belt tensioner is the top pulley on the passenger side
Using a socket, push the tensioner nut towards the middle of the engine until there is enough slack to remove the belt.
Repeat to remove the A/C belt. The tensioner is harder to reach because it is under the power steering fluid reservoir.
Cleaning out the pulley grooves with a wire brush
Reinstall the belts - A/C belt first
