Question on Door Show bars
Old May 26, 2011 | 07:06 PM
vvf-16's Avatar
vvf-16
Default Question on Door Show bars
I bought a set of chrome show bars and gave them a try at a car show last weekend. Question I have is on the Interior lighting with the doors proped open. I always thought that the Interior lighting turns off after 15 Minutes, is this true or did I get the wrong Info. I had them in for about 4 hours, and my car barely started when time to go. Does anyone know for sure if they turn off after a period of time, or do I have to disconnect my battery when I use the show bars. When Installed, they do latch the door handle catch. Any input would be great, Thanks
Old May 26, 2011 | 08:10 PM
bigblueman's Avatar
bigblueman
Works fine on my 2002, lights go off after about 15 minutes
Old May 26, 2011 | 08:52 PM
rdline's Avatar
rdline
mine off after 15 min , do many shows each year and my doors are open without bars , trunk too. I did disconnect the light under the hood , mine some of the time would run the battery down , short or something, got rid of it all together.
Old May 26, 2011 | 10:48 PM
jrose7004's Avatar
jrose7004
Mine goes off in my 04 after 15 minutes.
Old May 26, 2011 | 11:09 PM
rws.1's Avatar
rws.1
The lights go off in my wife's '04 between 10-20 minutes
Old May 27, 2011 | 02:34 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
like the underhood lamp, any movement however slight will re-activate the lights again for another 15 (or so) minute cycle. if the doors "rock" a bit on the bars and the weather is a bit breezy, that could be a cause. in addition, if those conditions exist, there is a good chance that your hood light also kept re-cycling. of course the timer relay could be shot and causing it also.
the car is designed to keep the battery from running down with a delayed 15 minute switch off system on the interior lights, yours just aren't cooperating.
Old May 27, 2011 | 03:56 PM
glorysends's Avatar
glorysends
Mine shut off after 15 minutes on my 99
Old May 27, 2011 | 06:07 PM
Vettmann17's Avatar
Vettmann17
Most likely whats happening. I noticed with my hood open the other day that if you touch the hood and it jiggles a little it will reactivate that light even with just a slight movement.
Old May 27, 2011 | 08:10 PM
vvf-16's Avatar
vvf-16
It's not my Hood light, I removed it years ago. Only thing that has changed is having a door show bar in...
Old May 28, 2011 | 02:33 PM
srs244's Avatar
srs244
yes, but it will behave in the same manner. the fact that your hood light is no longer isn't a factor. if you DID have one, i would be pretty comfortable tell you that the hood light would also be on or at least going on and off with the slightest change of position. the door sensitivity would behave in a similar way. unless those bars lock the door in a position that will keep it from moving even ever so slightly, that could be doing it. as i previously mentioned, it could also be that the delay relay took a dump.
Old May 28, 2011 | 05:13 PM
vetteman741's Avatar
vetteman741
From: Motorsports Capital of the World..Indianapolis Indiana
your RAP relay may be suspect
just an uneducated guess on my part, probably not any real help, sorry
To Question on Door Show bars
