doing a road course with my automatic. advice??
Old May 27, 2011 | 10:23 AM
ssidekickbp's Avatar
ssidekickbp
Default doing a road course with my automatic. advice??
Next week I am going to Ohio with a couple friends and we are doing a two mile road course out there. I am getting my car all ready in terms of brakes/fluid. That kind of stuff.
This is my first time at a road course track so I want to know what its the best method for racing my auto. trans around the track. such as Just leave it in drive or use the other gears? What traction control setting to use and such? Any advice would help. Thanks. I will post pics after I get back.
Old May 27, 2011 | 10:40 AM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
I''m not a road course expert by any means but I can tell you how I felt AFTER my first experience at Road Atlanta.....
Keep an eye on your trans temps if you are pushing it real hard. You don't have a trans cooler and the temps will rise pretty quick.
Don't leave it in Drive, that damn thing will shift down at the exact WRONG time while you are leaving a tight turn.
When shifting "manually" remember, it will not shift instantly when you move the shifter. It will take a second or two. If you are near Red Line when you move the shifter you will hit the Rev Limiter (very embarassing).
I learned all this while trying to be Mario Andretti on my first road course. You honestly can have a lot of fun just driving around it and not trying to set speed records.
Good Luck, be safe, have fun...
Old May 27, 2011 | 10:47 AM
02HREBlue's Avatar
02HREBlue
Dont do it haha
Old May 27, 2011 | 12:18 PM
Dominic Toretto's Avatar
Dominic Toretto
Auto C5s do have tranny coolers. The run through the radiator as do every other manufactured automatic car. Although it is not designed for roadcourse, I would recommend an external transmission cooler for this.
-Alex
Old May 27, 2011 | 01:25 PM
TorchRedRocket's Avatar
TorchRedRocket
...get a 6 speed.
Seriously though, I would turn on competitive driving mode at least. Maybe downshifting to 1st or 2nd (depending on speed obviously) prior to a corner or mid-corner so you don't have the lag that you normally would if you stomped on the pedal at say 30mph in 3rd or 4th.
Old May 27, 2011 | 01:37 PM
redrckt97's Avatar
redrckt97
I'd post this on the autocross-roadracing forum - there are some real fast guys with auto trans that could give you great advice. Much depends on how tight of a course it is - some you can run the whole course in 2nd. Take it easy and work your way up to speed - smooth is fast!
And be ready to be addicted... pretty much the most fun you can have with your Vette.
Old May 27, 2011 | 01:44 PM
AU N EGL's Avatar
AU N EGL
have fun be safe
Add an extra quart of oil
take an air hose and clean out the radiators
Change the brake fluid to DOT 4
Watch the trans temps
Set our tire pressures to 32 front and 30 rear COLD
Check and adjust before each session
You will need to manually downshift the auto going into corners, and upshift after the corners.
Post a report and pics when you get back
Old May 27, 2011 | 02:09 PM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Watch your tranny temps. If you start to get too hot, slow down and take it easy. Temp is the enemy of autos.
If you what to serious about this, get a tranny cooler and a Trans Go shift kit. You can also do some tunning to the tranny to make it shift faster. There are a bunch of things a good tuner can do to help a auto.
Autos do very well at a drag strip, but not as good at a road race.
Old May 27, 2011 | 02:10 PM
904pizza's Avatar
904pizza
I'm not Takin mine to a track. But I have an A4, readin this makes me assume it's ok to manually shift the A4? Is it built for that???
Old May 27, 2011 | 02:49 PM
dklowrider's Avatar
dklowrider
i think you should leave yours in D.
Old May 27, 2011 | 03:12 PM
AU N EGL's Avatar
AU N EGL
yup. IF you do it correctly.
Old May 27, 2011 | 03:33 PM
jrose7004's Avatar
jrose7004
When your trans temps start too get high, pull it in.
Old May 27, 2011 | 03:54 PM
wannaberacer's Avatar
wannaberacer
if it's mid-o, just keep it in 2nd or even 3rd. You're not trying to go fast in a straight line, you're trying to hit the turns right. Take it easy and have someone show you the turn ins for the track. Big beginners mistakes are early turn ins, and you will go slow because of this. Much more so than banging all the gears in the straights. Be sure to change your oil before and after (something I always do) and watch you trans temp like others said. Other than that, enjoy and have a great time!!!
Old May 27, 2011 | 04:17 PM
Rob04C5LM's Avatar
Rob04C5LM
Not much to it, in fact, less to think about for your first time out than on a manual. I would keep it in 2 and 3, don't bother with D or 1. Lift your hood between sessions to help keep things cool(er). Don't let your trans temp get too high, you'd be better to get off the track early one session than to push it and blow the trans.
Have fun and good luck!
Old May 27, 2011 | 04:25 PM
99 vett babycar's Avatar
99 vett babycar
use your breaks to drop speed entering a corner, then blip the throttle as you down shift - break parts are a lot cheaper than trani's. Try to keep you rpm up as high as possible.
Old May 27, 2011 | 05:36 PM
TorchRedRocket
^ I would definitely NOT do that...
To doing a road course with my automatic. advice??
