I finally got to pull some plastic off the engine to inspect the cooling fins. There is a ton of grass stuck in there. You guys were right about sucking up a lot of debris.
I have tried to use my air compressor to clean out the junk from the engine side. The one problem that I have is too small of a air compressor.
Other than buying a bigger compressor, does anyone have another suggestion on cleaning out this gunk?
