I have a 2000 that I have never had any problems with over heating until being in a parade on Memorial Day. I was almost to the red line and my DIC said 253 degrees. Thank god the end of the parade was near when it got to that point. I have had the car for about 10 months and don't know much of the history. One thing that I noticed is that the overflow tank is compleatly full. Could this be the reason for over heating? The radiator looks clean from when it was raised over the winter.
Any ideas would be greatly appreciated.
1 -check for debris in front of your radiator. These cars are notorious
for vaccuuming up road trash.
2- Did you have your A/C on while in the parade? It will help keep
your car cooler. Your electric cooling fans will run and keep air
circulating while idling along at slow speeds.
I had the A/C on as I have heard of that trick. In fact I was passing it on to other people that had never been in a parade.
If the thermostat was stuck would the car have been fine after it sat for about an hour? Our club had a picnic after the parade and the car was fine on the way home.
As for debris it was clean about 1 month ago. But I will try to get one of the kids to crawl under there and take a look so that I don't have to raise the car.
Does anyone think that too much coolant could be a problem? If it has nowhere to expand to could it cause a slow down or blockage?
is right. I have been getting up to 235 and feel that is too high.
Not sure what effect having too much coolant would have but get it to the correct level and see what happens.
Also pull the top radiator "cap" and look in between the radiators. I just did this and found a bunch of crap. I power hosed it and seem to be running cooler now. This photo is from the engine bay looking down.
You also might want to "burp" the system to see if you can get any air out. There are lots of threads regarding this and some very recent. If there is air the system will not circulate and could explain why your reservoir if full. Might be worth doing. It is simple and shouldn't take long, maybe 30 minutes top.
Have you verified that the fans are in fact running? Both fan grounds go through the ground pack on the top right forward frame rail directly adjacent to the hood riser.
All of the previous posts are great ideas and you should check for all of their suggestions. You didn't say if you changed the coolant (Dexcool) when you bought your car. It's a 2000 and no matter how you slice it, mileage or years, the coolant needs to be flushed and replaced, unless you have proof it has been done within the past 5 years or 100K miles. Make sure you use Dexcool and you also use distilled water. Or you could go to your friendly local Chevy "stealership" and they will do it for you.
My 98 overheated at high altitude was fine normal driving at lower elevation. My problem turned out to be a bad cap on the cooling system. Replaced the cap problem solved.
- Replace Thermostat
- Drain Old Coolant Mixture
- Check Hoses/Radiator for Debris/Trash/Gunk
- Fill with 60/40 Water/Coolant Mix
- Add 1 Bottle of Water Wetter
first rule of a parade, run the a/c to get the fans on right away regardless of the temp.
How will the A/C keep your car cooler? When I turn mine on, my temps go up at idle until I start moving and then the temps drop.
A/C off at idle in 96* heat, I see 189-192*. A/C on at Idle, it goes up to 215-220*. Both fans turn on.
On the highway in 96* heat, A/C off: I see 181-183* temps and A/C on 187-189* temps.....
What I've done is turn the HEATER up full blast and the fan on high. Yes, it makes things real warm for a bit but cools the engine down fast because, in essence, you are using the heater core as an auxiliary radiator. The system is pushing hot coolant through the core where it is cooling it off with thefan AND cooler water that was stuck in the core loop will now go to the block. It just makes things a wee bit uncomfortable in the cockpit for awhile.
By turning on the A/C you initiate the dual fans on the radiator. These fans are thermostatically controlled and w/o the A/C turned on they will not come on until the engine is getting pretty hot. To put it simply, having the fans on earlier due to A/C being activated is more beneficial in controlling the engine temp even though the drag of the A/C does indeed add heat to the engine. It's simply a trade off to get the fans running sooner in the heat cycle!
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Sound like the thermostat may not be opening all the way.
Here is a product we offer for the next time your in a parade or anytime you want to turn on your high speed radiator cooling fan without having to run the A/C and waste fuel and wear and tear on the A/C system trying to cool the world down.
It works great and will also help keep your automatic transmission running cooler too. It only takes 5 minutes to install. Check the installation video on this page too.
