$1,000 for a ebcm!
Old Aug 16, 2011 | 12:48 PM
countylawdog's Avatar
countylawdog
Originally Posted by 2003 electronblue
Just back from the Stealership had a Ebcm installed cost for the ECBM was $788.00 and another 212.00 for labor! also had a stuck window fixed $298.00 for a regulator and another $178.00 for labor! do these prices sound right?
Considering most dealerships labor rates are over $100 hr, labor costs are pretty much in line. However I just had my EBCM rebuilt for $150 + shipping, took off and installed myself (make sure you have plenty of patience). Had problems with power to the doors, window, etc, was 2 fretted wires in drivers door control panel ... fixed for under $100. I use this forum for all my repair problems, research as much as possible, so far any problem I have had ... somebody else had prior.
There is a wealth of knowledge here .... me personally .. I Thank all you folks
Old Aug 16, 2011 | 12:56 PM
cdkcorvette7's Avatar
cdkcorvette7
Originally Posted by 81c3
Did you at least get a tube of KY with that?
Originally Posted by 87SAM
I think sort of the other way around. No one seems to be able to fix 97 - 00 but they are able to repair the C1214 code on 01 - 04.
Old Aug 16, 2011 | 04:37 PM
dougbfresh's Avatar
dougbfresh
If it takes a dealer more than 30 minutes to R&R a front mounted EBCM their doing it with only 1 arm.
Old Aug 17, 2011 | 02:40 AM
904pizza's Avatar
904pizza
Guy in Winona MN fixed my ECBM, he's in the auction site. $50! Getting it out was tough, but since I got that part back only code I throw now is 1287 for steering wheel position sensor. It's shown for a long time, just gotta get up the nerve to take it all apart to fix!!! But fixing the ECBM cleared a bunch of codes!!!
Old Aug 17, 2011 | 03:50 AM
Txsailor's Avatar
Txsailor
The swps isn't that hard to replace. My car has the telescoping wheel and I did it in a couple of mornings before work ( I work second shift) just have a helper to help stab the column back in and hook everything back up like it was. No sense dreading it and putting up with the active handling not working right.
Old Aug 17, 2011 | 09:45 AM
pjensen1954's Avatar
pjensen1954
Originally Posted by The NNIAL8R
Yes and no....They only fix 97-99s.....2000 and newer cant be fixed :
I think you have it backwards, my 01 ecbm was repaired by abs fixers for 200.00 (approx) I think it's 2000 and older that they don't fix
Old Aug 18, 2011 | 01:19 AM
mosimann's Avatar
mosimann
Also took mine off but it couldn't be repaired. Bought an used/refurbished unit from the auction site for $250 and sold my old one to absfixer for $50.
Old Aug 18, 2011 | 10:19 AM
VetteCrazyRichard's Avatar
VetteCrazyRichard
Next time try www.absfixer.com...for $150 repair of your old module. Do it yourself or get a friend to help who knows mechanics.
