Oil Extractor
Old Jun 4, 2011 | 08:03 PM
ebmorse's Avatar
ebmorse
Cruising
Default Oil Extractor
Inquiring to see if anyone has used or has information on the merits of using an oil extractor through the dipstick tube to change the oil on a c-5. Given that one still has to change the filter, it would appear easier to remove the oil using this method than the ramps and jack I use in my home garage. However I don't want to compromise the process and end up with partial dirty and new oil together. Experiences, thoughts? Thanks. vetteboy
Old Jun 4, 2011 | 08:06 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
How is it easier if you still have to jack the car up or put it on ramps to change the filter?????
Old Jun 4, 2011 | 08:40 PM
Carcass's Avatar
Carcass
So,you extract the oil through the dipstick tube(which can't possibly get all the old oil out)THEN,you jack it up and change the filter?
Yeah,I'm not understanding how that's easier,unless you're not planning on changing the filter,but if you're not doing the filter,why bother changing oil at all?
Old Jun 4, 2011 | 08:52 PM
Jim2003's Avatar
Jim2003
Never ever would I use that. Jack it up, pull drain plug, let it drip for an hour, take filter off, wipe area clean, put on new filter, clean drain plug area, put plug back, put in new oil.
The life of an engine is its new oil and filter. Do not cheat on this two important areas of any care engine!!!!!
Old Jun 4, 2011 | 09:23 PM
SCM_Crash's Avatar
SCM_Crash
I changed the oil on a stock height Vette in 20 min including getting it on and off the ramps. An extractor seems like it'd take more time.
Old Jun 4, 2011 | 09:25 PM
Cybermind's Avatar
Cybermind
I use an oil extractor regularly on my wife's car. Works well. Unfortunately, you can forget about using one on a C5. The oil pan has to many baffles in it which does not allow the tube to pass. I tried.
Old Jun 5, 2011 | 12:03 AM
It's not really that difficult to just do it this way.
Old Jun 5, 2011 | 07:37 AM
Cybermind's Avatar
Cybermind
FYI, oil extractors cannot be used on C5's because of the batwing oil pan design but they are the recommended method of changing the oil on a multitude of exotic sports cars and the only way to change the oil on most speed boats. I actually tested them on several cars by extracting the oil from the dip stick hole and then verifying what was left in the oil pan by removing the drain plug. There wasn't a drop left.
So, they do work well. Just not for our Vettes.
Old Jun 5, 2011 | 08:53 AM
DeeGee's Avatar
DeeGee
Having changed the oil on my boat using an extractor, I'd say the 10 minutes it takes using the conventional method is waaaaaaaaaaaaaaayyyyyyyyyyyy the best option.
Old Jun 5, 2011 | 09:15 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
My wifes car has the filter on the top, I used the extractor to change her oil, tried it once on the vette and the tube will not get to the oil pan thru the dipstick. I just jack car up one side, slide a stand under it remove plug and filter, drop it back down for a few minutes then back up and replace , much quicker for we than ramps.
Old Jun 5, 2011 | 09:24 AM
FNFastZ06's Avatar
FNFastZ06
I only use an Extractor on my twin inboard engined boat, and to remove tranny and differential fluids.
Old Jun 5, 2011 | 07:07 PM
ebmorse's Avatar
ebmorse
Cruising
Thanks to all for the advice, ie skip the oil extractor. Noted that in the description on changing the oil on a c-5, no one mentioned using ramps, drain, THEN JACK UP BACK HIGHER THAN FRONT AND DRAIN SOME MORE. Read a couple of articles a few years back that said that is the proper way. I have been doing it. Thoughts??? ebm
Old Jun 6, 2011 | 09:00 AM
FNFastZ06's Avatar
FNFastZ06
I jack it up front and rear level onto stands. While oil is draining, is a good time to slide around underneath and just eyeball all is OK, or nut and bolt a few key components. Then raise the rear about 1-2" with jack to be sure all the gunk is out. Return to stand and finish up.
To Oil Extractor
