Where is the warning chimed located?
Old Jun 11, 2011 | 02:36 PM
Fast one's Avatar
Fast one
Default Where is the warning chimed located?
I couldn't find anything in the shop books, I want to add a shut off switch to it if possible.
Old Jun 13, 2011 | 12:41 PM
rboineau's Avatar
rboineau
I'd love to kill mine as well, but I believe that it is so tied into the electronics that you would have to be a computer wizard to do the deed.
Old Jun 13, 2011 | 01:01 PM
DeeGee's Avatar
DeeGee
Its deep in the IPC. Like you, I'd love to cut the wire
Old Jun 14, 2011 | 07:34 PM
Cosmic Charlie's Avatar
Cosmic Charlie
I think it plays through the stereo speakers (?)
Old Jun 15, 2011 | 05:47 PM
chrisj's Avatar
chrisj
St. Jude Donor '12
It has its own internal speaker and is on the back of the instrument panel. I'm local to RadioFlyer and had him wire a kill switch into mine. That way I can have my headlights up/on at car shows (showing off his light cannons) and the doors open yet not have the chime going.
He figured it out pretty easy. Send him a PM and see if he can give you a hand.
chris
Old Jun 15, 2011 | 06:02 PM
BigTattooMan's Avatar
BigTattooMan
St. Jude Donor '10
I just had mine out today and thought of this thread so I snapped a picture
John
Old Jun 15, 2011 | 07:14 PM
mcgilles's Avatar
mcgilles
I have something slightly different in mind. I'm sure I could figure it out, but its sure easier to use other people's experience.
do you know if it was done in the harness for the cluster or is it a mod to the cluster itself? I think there's a dedicated wire to indicate lights on to the cluster. I haven't looked into it that deeply, but I've always wondered if that wire alone would be able to kill the chime. it might also kill the illumination though, not sure!
Old Jun 16, 2011 | 08:23 AM
Thanks for the info. Saved for future reference.
Old Jun 16, 2011 | 12:00 PM
chrisj's Avatar
chrisj
St. Jude Donor '12
Yep, that pic looks very familiar. I have a recollection that it was a single wire that did the job. For some reason green sticks in my mind. But DO NOT go based off of my fuzzy memory. I did the disassembly while RadioFlyer worked on other pieces. Basically I was his "apprentice" for the install. I did the piddly stuff that kept me entertained and kept the job moving. Plus it was fun to rip half my car apart!
chris
Old Jun 16, 2011 | 03:23 PM
Fast one's Avatar
Fast one
Thanks for the replys.
Old Jun 16, 2011 | 10:25 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Also, if you fiddle with the wrong wire you may have a permanent chime....wouldn't that be nice!
To Where is the warning chimed located?
