Missing Plastic Cap in Headlight
Old Jun 14, 2011 | 09:26 PM
malligood55's Avatar
malligood55
Default Missing Plastic Cap in Headlight
When my headlights came on tonight I noticed the plastic cap missing out of the popup assembly. Any idea where I can get one?
Old Jun 14, 2011 | 09:37 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Here is a thought......The GM Dealer, About 3.00 each.
Old Jun 14, 2011 | 09:49 PM
malligood55
Old Jun 14, 2011 | 09:50 PM
derty01's Avatar
derty01
Or you could buy the newer model surrounding so you do not have to worry about it again, this is what I am doing since both sides are missing the circle.
Old Jun 14, 2011 | 09:55 PM
malligood55
Old Jun 14, 2011 | 09:56 PM
malligood55
Do you happen to have part numbers and cost?
Old Jun 14, 2011 | 10:02 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I thought all of the headlight bezels for the C5 have access plugs? I know they changed the style of the plugs based on year, however the plugs are still required as I don't believe they created headlight bezels/shrouds without access holes/plugs.
To the OP - you can also purchase them from Corvette Central, Mid-America or GM Partshouse.
Old Jun 14, 2011 | 10:11 PM
Mr.Bill's Avatar
Mr.Bill
All C5 factory headlight bezels that I have seen all have the hole, But there are 2 different sizes. If there is a bezel wothout the hole I have never seen one and would like to see one.
Mr.Bill
Old Jun 14, 2011 | 10:13 PM
Mr.Bill's Avatar
Mr.Bill
More info Please.
Old Jun 14, 2011 | 10:20 PM
jornahow's Avatar
jornahow
Before you buy a replacement take a quick look in the headlight well area with a flash light. Mine was missing on one side and that's where I found it; it either shook loose when the light was down or by good fortune landed there from the up position.
Old Jun 14, 2011 | 10:25 PM
MSG C5's Avatar
MSG C5
...I also suggest that when you (re)install your new plug, duct tape it to the inside. Any serious light work I perform usually requires me to remove the entire bezel anyway.
Old Jun 14, 2011 | 10:45 PM
jrose7004's Avatar
jrose7004
Ecklers has them too.
Old Jun 14, 2011 | 11:12 PM
JohnsC5's Avatar
JohnsC5
A piece of black duct tape has worked just fine for me.
Old Jun 14, 2011 | 11:15 PM
momo20's Avatar
momo20
check in and around and below your headlight..i know mine came off and it was chillin down below on the frame..i used some rtv sealant and it has yet to come out again
Old Jun 14, 2011 | 11:31 PM
Bills03Coupe's Avatar
Bills03Coupe
P/N; 10435410, around $3.00 (for my 2003, not sure if all C5's are the same P/N)
Old Jun 15, 2011 | 01:29 AM
Jistari's Avatar
Jistari
Old Jun 15, 2011 | 01:45 AM
Rexde1's Avatar
Rexde1
I found mine over by the other headlight under the hood after about 6 months.
To Missing Plastic Cap in Headlight
Old Jun 15, 2011 | 02:41 AM
NorCalVette Kid's Avatar
NorCalVette Kid
St. Jude Donor '09
That's where I bought mine. I bought 4 and all 4 are now gone!
Old Jun 15, 2011 | 08:17 AM
That's where I bought replacements when I lost a few of them.
Old Jun 15, 2011 | 10:19 AM
PhilsFRC's Avatar
PhilsFRC
Default Headlight Bezel Caps
Went through this with my '99 FRC. Turns out there is an "early" cap and a "late" cap. The early (changeover in '99 or '00 as I recall) cap is slightly larger and snaps in place. The late cap is smaller and twists and locks in place. The early cap is NLA from GM, and GM's solution is to replace both headlight surrounds with "late" so you can use the "late" cap--which is B.S.. Eckler has reproduction early caps which solve the problem. FWIW.
