Lowering (Front ) Question
Old Jun 15, 2011 | 09:41 AM
Button's Avatar
Button
Default Lowering (Front ) Question
Really need help... I can't get the front 10 MM bolt to move on either
side try as I may. I know the direction Counter-clockwise but it just won't move more the a tinny fraction.. Any help would Help??
(Play on Words)
Old Jun 15, 2011 | 09:51 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
(Play on Words)
You might need to put some penetration oil on the threads and let it sink in. That should help.
If not you may need to take the tension off the spring by lowering the A-Arm down, thus freeing any load on the bolt - sometimes this just has to be done!
Thanks,Matt
Old Jun 15, 2011 | 10:10 AM
bumble-z's Avatar
bumble-z
Try several soakings over a 24 hour period,sprayed from the top, to each adjuster, with PB Blaster.
If still unable to move, try this proceedure.
Good luck.
http://forums.corvetteforum.com/1577825347-post1.html
Old Jun 15, 2011 | 10:14 AM
m6 c5's Avatar
m6 c5
I have not had any luck with lowering the front on my car, I used pb blaster and let it soak along with removing the tension off the spring and it still would not budge. Heck I broke my 1/4" ratchet and cracked a 3/8" drive socket trying to get it to turn and it hasnt even budged. Then I figured I had nothing to lose at this point and went with the get a bigger hammer concept and used pipe wrench (yea I was a little pissed off when I pulled it out) and that wouldnt even get it to budge. I feel that I am going to break the rod before I get it to actually turn so as of now I have been defeated on lowering the front on stock bolts.
Old Jul 11, 2011 | 09:36 PM
Vettitude's Avatar
Vettitude
I'm having the same issue. Took it to a garage/vette tuner &'he couldn't break it free either.
Did you ever have success with you front bolts?
Old Jul 11, 2011 | 09:38 PM
m6 c5's Avatar
m6 c5
I never had any luck with mine but I am going to be putting on a new front spring in the near future so Im going to fix my little problem then.
Old Jul 11, 2011 | 10:04 PM
4SFED Z's Avatar
4SFED Z
Where are u located? I can't see on my phone
Old Jul 11, 2011 | 10:05 PM
buckg2's Avatar
buckg2
soak it, soak it, and soak some more. I spun the nut inside the spring on one side, now I'm screwed
Old Jul 11, 2011 | 10:10 PM
m6 c5's Avatar
m6 c5
If you were asking where I am located Im in Yorktown Va.
Old Jul 12, 2011 | 05:32 AM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
I had the same problem you all are having and I had to take my spring out and put the bolts in a vise to get them to break free. Good luck with the soaking but I never had any luck with that.
To Lowering (Front ) Question
