[Z06] whos using ls7 manifolds?
Old Jun 19, 2011 | 03:34 PM
BuddhaZ06's Avatar
BuddhaZ06
In the latest camaro now magazine, they put an ls9 blower on a ls7 and kept manifolds cuz headers made less HP but made more torque. They reused them on the ls9. If the can support blown 640hp on bigger cube engines, they should flow plenty good for a h/c/I 346. Just my. 02
Old Jun 19, 2011 | 03:40 PM
AU N EGL's Avatar
AU N EGL
That is a gamble. where LG Pro LTs WILL get the flow you want. so will Kooks 1 7/8s, AMR 1 7/8s
Old Jun 19, 2011 | 03:43 PM
MTPZ06's Avatar
MTPZ06
Not the first time I've seen an FI setup use shorties over LT's. Like I said before...IMO, the LS7 manifolds are comparable to a set of shorties.
Again, not trying to dissuade you from making your decision...but I have seen nothing to convince me that they are any better than a set of shorties. Perhaps the additional gains you're seeing are a result of incorporating the 3" mid-pipe? Not everyone that swaps to the LS7 manifolds also swaps in the mid-pipe. Could be some more HP there?
Old Jun 19, 2011 | 04:10 PM
BuddhaZ06's Avatar
BuddhaZ06
Old Jun 19, 2011 | 04:23 PM
Carlmc1's Avatar
Carlmc1
I have them with a aftermarket x pipe and I would bet anything my setup puts down similar numbers to a comparable car with LTs and probably more once the cats are removed. The only negative is the weight.
Carl
Old Jun 19, 2011 | 04:54 PM
BuddhaZ06's Avatar
BuddhaZ06
Thanks for the positive input. Ill be dynoing after manis and tune. That will tell me a lot.
Old Jun 19, 2011 | 05:42 PM
BuddhaZ06's Avatar
BuddhaZ06
I Like hearing real world results. Not people judging with no experience.
Old Jun 19, 2011 | 06:14 PM
MTPZ06's Avatar
MTPZ06
With all due respect, I like hearing real world facts based on proven emperical data...not unqualified statments based on nothing more than one's opinion. Just my $0.02...
Sounds like you've convinced yourself...let us all know what real world results you get. Before & after dyno's w/o changing the existing tune, 1/4 mile ET's and trap speeds, etc.
Old Jun 19, 2011 | 06:20 PM
BuddhaZ06's Avatar
BuddhaZ06
I sure will. Not before and after dyno but trap speed for sure. I just like hearing what people thought of them who have used them and with experience. Which is why I made the thread asking who IS using them.
Old Jun 19, 2011 | 06:24 PM
BuddhaZ06's Avatar
BuddhaZ06
How much are these 1-7/8 headers? Like I've said, this is a full budget build. Seeing how fast I can go and how cheap I can do it.
Old Jun 19, 2011 | 06:44 PM
MTPZ06's Avatar
MTPZ06
Check out post numbers 34 & 36...
http://forums.corvetteforum.com/c5-z...-shorties.html
Old Jun 19, 2011 | 07:14 PM
BuddhaZ06's Avatar
BuddhaZ06
So 11/11 on stock c5 untuned with cats. I'm head cam intake without cats and will get retuned. If I make 20 ill be happy for $200 that I can get my money back on if not make money.
Old Jun 19, 2011 | 07:51 PM
  #33
AU N EGL's Avatar
AU N EGL
Budget Cheap and HP is an oxymoron.
The Least expesive way is just put on a CAI, Blackwing or Haltech and a dyno tune.
Total $800 that will get the MOST HP for the least amount of money
Bolting on other parts wont get you much if any more
Old Jun 19, 2011 | 08:23 PM
  #34
BuddhaZ06's Avatar
BuddhaZ06
I already have everything else. The budget just came recently. I'm just lucky I got to keep the car.
Old Jun 19, 2011 | 10:14 PM
  #35
MTPZ06's Avatar
MTPZ06
H/C/I with a re-tune, that may be attainable.
Old Jun 19, 2011 | 10:39 PM
  #36
BuddhaZ06's Avatar
BuddhaZ06
I'm gonna try to dyne before and after but I doubt it. For sure after
Old Jun 19, 2011 | 10:44 PM
  #37
MTPZ06's Avatar
MTPZ06
Talk to your dyno tuner...they may be real interested in before and after results for these manifolds as well. I'm sure they wouldn't mind doing a baseline "before" run.
To whos using ls7 manifolds?
Old Jun 19, 2011 | 10:50 PM
  #38
BuddhaZ06's Avatar
BuddhaZ06
Ya I'd really like to but he's far away just to go dyno
Old Jun 19, 2011 | 10:53 PM
  #39
BuddhaZ06's Avatar
BuddhaZ06
But we'll see. Have some time next couple weekends
Old Jun 19, 2011 | 11:59 PM
  #40
ctusser's Avatar
ctusser
That's about what longtubes make on a stock car. The longtubes in themselves are only good for 10-15 on a bolt on only car and another 5 or so with a tune.
