C5 oil drain plug ?
Old Jun 19, 2011 | 05:55 PM
killain's Avatar
killain
Oldtimer
Default C5 oil drain plug ?
Have any of you swapped out the stock oil pan drain plug with a newer magnetic one? Was putting in the magnetic one worth the price and effort? Thinking of installing one with the up coming oil & filter change ?
Old Jun 19, 2011 | 06:13 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I have never used one, It isn't a bad idea, I might get one for my next change.
Old Jun 19, 2011 | 06:20 PM
CHJ In Virginia's Avatar
CHJ In Virginia
Absolutely spend the $5 and get the GM magnetic plug from the stealership. I switched at my first oil change. Every time I take it out there is a fine coating of iron particles adhered to the magnet that the filter did not catch. It will keep that junk fron circulating and remove it from the engine !!!
Old Jun 19, 2011 | 06:44 PM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
I've had one for serveral yrs & feel it's well worth the extra insurance. Go for it..
Old Jun 19, 2011 | 09:05 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
i don't use a magnetic plug, but i do have a heavy duty magnet afixed to the bottom of the oil filter and i re-install it each time i change the filter and the oil. you'd be surprised at what the bottom of the filter looks like when you cut it open to see if it does anything. believe me it works.
Old Jun 19, 2011 | 09:20 PM
ROJ#79's Avatar
ROJ#79
Old Jun 19, 2011 | 09:23 PM
Get the magnetic plug. It will capture any fine metal particles floating around.
Old Jun 19, 2011 | 09:31 PM
spdislife's Avatar
spdislife
...and if you find some larger bits attached, you'll have a heads up to more serious problems.
To C5 oil drain plug ?
