Vararam question..
Old Jun 24, 2011 | 05:29 AM
Kamauxx's Avatar
Kamauxx
Default Vararam question..
I searched, couldn't find the answer.
I have a Z06 with the screens removed from the bumper where the Vararam's holes line up. If I install this intake would I be at risk for having things (leaves, plastic bags, etc) sucked into my TB/intake?
Old Jun 24, 2011 | 06:46 AM
BADBIRDCAGE's Avatar
BADBIRDCAGE
If you have your filter in place nothing is going to go through it to the TB. You are correct that leaves and other small animals could be sucked up into the air intake unless you do something like this.
Old Jun 24, 2011 | 06:58 AM
Kamauxx's Avatar
Kamauxx
That's not a bad idea. Pics from further back?
Old Jun 24, 2011 | 07:50 AM
BADBIRDCAGE
I'll get em for you later today. The screens pretty much disappear which is what I wanted.
Old Jun 24, 2011 | 08:41 AM
HT1663WB's Avatar
HT1663WB
Why wouldn't you just put the Z06 screens back in? I also have a Z and the Vararam. There are no issues using the factory screens.
Old Jun 24, 2011 | 09:04 AM
Kamauxx's Avatar
Kamauxx
Short story long?
Got hit by a dog.
Bumper needed replacing.
Dealership was on it's 5th week, and waiting on the screens to be shipped.
Dealership got the wrong screens.
I got fed up and just took the car back without the screens.
Picked the screens up from them a couple weeks later.
Tried to install and realized I'm either not flexible enough or my arms are too short.
Screens are in the garage now.
...question, does the bumper have to come off for the screens to be replaced?
Old Jun 24, 2011 | 09:37 AM
chassed's Avatar
chassed
Sell me your screens?
Old Jun 24, 2011 | 03:38 PM
BADBIRDCAGE
Here's you farther back shots.
Old Jun 24, 2011 | 04:00 PM
corvettecrazy2's Avatar
corvettecrazy2
How did you get them to stay in place? is there a DIY write up anywhere cause i would be really interested.
Old Jun 24, 2011 | 04:07 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Nope, I put mine on and used double sided tape. They are OEM screens. Put the screens in so it will look better and you wont have to worry about it.
Old Jun 24, 2011 | 05:18 PM
BADBIRDCAGE
I made those from a piece of aluminum rain gutter screen that I bought at Home Depot for under $3.00. They stay in place because on the lower edge there is a 90 degree bend that tucks under the front facia lip, at the top they are held in place by snapping in behind the facia and in front of the intake and I bent one corner over at the outside edge of the intake to keep it from sliding sideways. All you need is a pair of tin (aviation) snips and a straight edge to bend the screen over. Took less than an hour from start to finish.
Old Jun 24, 2011 | 07:00 PM
zeevette's Avatar
zeevette
That dog must have been really haulin' ***.
Old Jun 25, 2011 | 12:55 AM
yaknow's Avatar
yaknow
I have a FRC with Vararam installed Z06 screens with velcro. Easy to slide in and, easy to remove .
Old Jun 25, 2011 | 06:04 PM
ZeekDuff's Avatar
ZeekDuff
That's good to know. I just ordered the complete VR system and these to match;
http://shop.corvettecentral.com/C5-1...-p9085790.html
these;
http://shop.corvettecentral.com/C5-1...-p6021114.html
If you're ordering the ZO6 screens, be careful, they also have OEM screens that are $144 EACH! They also have a stainless steel brake duct screen that looks darker in the pict, so I went with the zinc chromate.
I got the side vent screens too, just so everything matches.
Best regards,
...z
To Vararam question..
