[Z06] wheels
Old Jun 24, 2011 | 08:02 PM
JFG Racing #1's Avatar
JFG Racing #1
Default wheels
I'm going with Cray scorpion rims 19x9 and 20x10.5. tire sizes 245/35/19 in fronts and 305/35/20 with nitto 555 drag radials in the rear. what do you guys think?
thanks
Old Jun 24, 2011 | 08:32 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
thanks
Nice wheels.... but they are HEAVY.
Just something to consider.
Toque
Old Jun 25, 2011 | 02:11 AM
striper's Avatar
striper
Toque
I was going to say the same thing. First of all, as you go up in diameter the wheel weight will increase to begin with. The way Cary wheels are made they are heavier than a lot of other wheels. You're going to have some real heavy wheels which do nothing for enhancing the performance. Look into CCW's wheels, excellent quality and much lighter. www.ccwheel.com.
Old Jun 25, 2011 | 09:50 AM
BLKOHZ06's Avatar
BLKOHZ06
not much rubber on the ground !
Old Jun 25, 2011 | 01:33 PM
FYRARMS's Avatar
FYRARMS
I think a couple of things...
a) Front tires are pretty narrow. I run 265/30/19 on my Crays up front.
b) Your rear size is VERY tall.
c) I agree with Toque. The wheels are very heavy. Most Chinese cast wheels are. Mine were on the car when I bought it, but will be swapped for more performance-oriented Forgeline wheels over the winter.
d) Not sure I understand the whole 20" drag radial thing. If someone needs traction, they should stay away from 20" wheels all together. The idea is to get a taller sidewall. If someone wants to look good and run 20" wheels, just use a standard radial tire. Swap to 18" drag tires at the track.
Old Jun 25, 2011 | 05:04 PM
LSOHOLIC's Avatar
LSOHOLIC
They^^^ have all summed it up. Your going the wrong way !! IMHO.
Thanks...
Old Jun 25, 2011 | 05:48 PM
AU N EGL's Avatar
AU N EGL
No offense Drag Radial and 20" rim is an oxymoron
for a drag radial a 17" rear rim with a tall side wall DR would be much better for wt and launch
Old Jun 25, 2011 | 09:13 PM
danziger's Avatar
danziger
If it is just for looks, I say go for it!
To wheels
