Pinging
Old Jun 26, 2011 | 10:53 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Originally Posted by flynbyu2
Every other car with a computer I own has "knock sensors" which will retard the timing if you use sub-grade gas. Performance is definately degraded, but at least it wont grenade your motor.
I find it hard to believe the Corvette computer doesn't have the technology of my '97 Acura?
The Corvette does, That is why I say he has some issues going on.
Old Jun 26, 2011 | 11:34 PM
MNR's Avatar
MNR
Originally Posted by sogysailor
LINKY NO WORKY!!!!!!!!!!
I wonder, as a test, try some octane boost?? Maybe 1 tank and see results. Also someone mentioned that ethanol helps detonation issues.Don't they add that or something like that during the winter in some states?
Originally Posted by UniqueDoug
wrong vid...ill get one later
Going to check the plugs tomorrow to see if they are gapped correctly. Thats a start, huh?
I should add that under certain rpm levels and throttle positioning you can hear some air noise like "shhhhhh" or a whistle noise. I diagnosed it as something to do with the VR and never thought twice about it. This probably has something to do with the issue I am having.
Old Jun 27, 2011 | 10:23 AM
UniqueDoug's Avatar
UniqueDoug
Does anyone's engine "ping" during light acceleration around 1300-1700rpm or so? Does this have any effect on the engine?
I want to diagnose this noise I hear as light pinging, it sounds like a bolt is loose and its rattling on a piece of metal, if you know what I mean? Like a vibration a little bit. Only happens at ~1.3k to 1.7k in 1st gear, after that I cant really hear it because of other noise.
Ok, I may be losing it but is that the right video?? I heard no noise and you only got to about 1200 rpm's.
Old Jun 27, 2011 | 10:32 AM
sfc rick's Avatar
sfc rick
That's a bad video didn't hear anything unusual in it!
Besides if it's pre-ignition pinging you will only hear it under a load during acceleration.
Tape your iphone on the top of the engine, close the hood, run around the block under load then pull iphone and post the video.
Old Jun 27, 2011 | 11:18 AM
UniqueDoug's Avatar
UniqueDoug
Tape may not hold well once the engine bay heats up, I'd recommend a sheet-metal screw.
Old Jun 27, 2011 | 11:46 AM
MNR's Avatar
MNR
Will do...
I thought I uploaded it to photobucket...thats not it though. I hate this f'in sheet haha. I think thats when the shuddering happened, I tried to get it on vid.
...not happenin
Maybe a 2in nail will hold?
Old Jun 27, 2011 | 05:54 PM
UniqueDoug's Avatar
UniqueDoug
Will do...
...not happenin
for the video
Old Jun 27, 2011 | 06:02 PM
MNR's Avatar
MNR
Update: I took it out today but could not get a good sound of the pinging, all you heard was background noise. Going to try a different mounting location later tonight.
UniqueDoug...
