2000 C5 65k. Experiencing alternating display "security" "service vehicle soon" about every 10 minutes while driving. Had 1 no start. Disconnected battery waited 20 minutes started but same displays. How can I find they cause of the "service vehicle soon" display?
Thank you
William Mikesell
Pull the codes and see what it's complaining about.
I did, they were all by "H". I have left the battery disconnected today and will pull the codes again tonight. Thank you very much for your help.
William Mikesell
Try using your other key and see if there is any difference
No difference. Codes: SDM: U1000, U1064, 60IPC: U1160, U1176, HVAC: U1064, U1160, LDCM: U1064, A6SCM: U1255,U1064,
A1RDCM: U1064. All are "H". Was not able to clear as DTC will not go into scan. Disconnected bat. overnight, after reconect approx. 1 minute underhood light and security light on after opening drivers door. still no start. Liights went off. No power to courtesy lights, and under hood. All other manual operated switches work ok. No column lock or unlock. Battery is 1 yr. old OE Delco fully charged, cables excellent. Appreciate very much your help.
William Mikesell
