Convertible top rubbing
Old Jul 2, 2011 | 05:12 PM
OldGuard's Avatar
OldGuard
Default Convertible top rubbing
My 2001 convertible is starting to rub the paint where it touches the trunk area on the passangers side. There is a spot about 1/4 inch wide and about 4 inches long. There is also a mark on the convertible top on the edge. This year is the 1st I have ever noticed this. I would send photos but I don't know how to add photos to this.
Is there some way to adjust the way the top sits when in the up position?
Old Jul 2, 2011 | 05:22 PM
STL94LT1's Avatar
STL94LT1
I had the same issue with my 01.
http://www.c5forum.com/forum/ubbthre...te_id=1#import
Old Jul 2, 2011 | 08:04 PM
Razzputon's Avatar
Razzputon
This was a known issue with earlier verts. You can buy a newer weather strip to replace the old one that goes along the back of your vert top. The top should look like it does not sit flush to your trunk area but if you look closer the weather strip has sealed the back area. Thsi will keep your top from rubbing on your cars paint.
Old Jul 2, 2011 | 09:01 PM
dougbfresh's Avatar
dougbfresh
http://www.c5forum.com/diy/01topfix.php
Old Jul 3, 2011 | 12:21 PM
tonyb47's Avatar
tonyb47
I had the same problem with my 2000, you need need weathersripping on the last bow, I bought mine from gmpartsdirect, don't wait it will get worse, the weatherstripping keeps the top off the deck. Before I replaced it I couldn't fit a thin piece of cardboard between the top and the the deck, after I can almost fit my finger.I wish i new sooner before the damage was done.
Old Jul 3, 2011 | 04:08 PM
DeeGee's Avatar
DeeGee
http://www.corvetteactioncenter.com/...+Plastic+Strip
Old Jul 3, 2011 | 09:34 PM
Kevin Kuse's Avatar
Kevin Kuse
This helped me.
http://forums.corvetteforum.com/c5-g...ing-paint.html
Old Jul 3, 2011 | 10:26 PM
OldGuard's Avatar
OldGuard
Thanks again for all the good information. There sure is a lot of good knowledge here on this site. I'm sure I will be using more of it at another time.
Old Jul 8, 2011 | 09:16 PM
OldGuard's Avatar
OldGuard
I ordered a new seal it should be here Sat. Now if I can figure out how to install it properly, I have shop manuals but they are not real clear about this. I don't know if there is any adhesaves used or not. Does anyone have any tip on installing this?
Old Jul 9, 2011 | 03:28 AM
DeeGee's Avatar
DeeGee
Looks like the 5th Bow Seal is only held on by 2 nuts at each end. There's no mention of adhesive in the procedure. I guess it'll be obvious when you remove the old seal if it was glued in place or if its a push fit.
Document ID# 656624
2002 Chevrolet Corvette
Weatherstrip Replacement - Folding Top Number Five Bow
Removal Procedure
Position the top closed.
Remove the protective pads from the ends of the #5 bow covering the nuts to the 5 bow.
Remove the nuts attaching the ends of the weatherstrip to the 5 bow.
Remove the weatherstrip.
Installation Procedure
Install the #5 bow weatherstrip.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the nuts to the ends of the weatherstrip.
Tighten
Tighten the nuts to 4 N·m (35 lb in).
Install the protective pads to the weatherstrip nuts.
Install the protective pads to the ends of the bow.
Reposition the folding top to the original position.
Old Jul 9, 2011 | 04:22 PM
STL94LT1's Avatar
STL94LT1
Would you please take pics of the new seal compared to the original?
To Convertible top rubbing
