Tire Pressure Accuracy
Old Jul 7, 2011 | 02:20 PM
don hall's Avatar
don hall
Default Tire Pressure Accuracy
Several searches without finding an answer.
I'm questioning the tolerance factor in the tire sensors vs. the accuracy of tire gages (dash reading). I have compared my gage (below) to a gage at Big O Tires, and they were comparable within 1/2 lb. Both gages were analog, which made a scientific comparison "iffy".
The gage shown registers 33 lbs. as tire pressure, while the dash reading registers 30 lbs. Is a tolerance/variance of 3 lbs. acceptable?
Old Jul 7, 2011 | 02:56 PM
hotwheels57's Avatar
hotwheels57
I don't have TPS on my Z16, but I do in our daily drivers (Tahoe and Silverado). Both of those consistently show lower on the DIC than shown on either a digital or analog gauge (my preference). I'm not sure if there's a manner to calibrate them to higher accuracy or not.
The 3# variance might be enough to trip the DIC warning. Occasionally, I've gotten the DIC message to "check tire pressure" which is later followed by an ONSTAR e-mail warning a tire pressure is low. I know it's not the case since I check the air pressure regularly, especially during the winter months.
Old Jul 7, 2011 | 03:08 PM
jrose7004's Avatar
jrose7004
I've never found a whole lot of difference between the TPMS and any of several gauges that I have.
Old Jul 7, 2011 | 03:14 PM
don hall's Avatar
don hall
Default pressure
Thanks for the response. I didn't even consider the 'warning' light as the tire pressure always increases about 4 # when heated.
I have more confidence now that your DIC is reading at a lower pressure level than your analog gage. So far, the score is 2 - 0 in favor of the analog gage reading higher than the DIC.
Old Jul 7, 2011 | 03:17 PM
LS WON's Avatar
LS WON
I find a different between TPM's and Accu-Pressure tire guage of 2 lbs. The Corvettes TPM reads 2 lbs less than guage If I remember correctly.
Old Jul 7, 2011 | 03:20 PM
don hall's Avatar
don hall
Jim, define "a whole of difference"...... less than 3#?
And, do your tire sensors read less than the pressure gages?
Old Jul 7, 2011 | 03:24 PM
don hall's Avatar
don hall
That is consistent with what has been reported, so far.
Old Jul 7, 2011 | 03:30 PM
don hall's Avatar
don hall
Default pressure
From the net:
"TPMS are activated by motion. They have a real battery.
They also stay energized for a while after you stop. TPMS takes traveling at 40mph plus for several miles after air fill before it reads accurate..
It isn't designed to be used to gauge air pressure when filling, it's designed for movement pressure to alert you of a potential problem.."
Just learned something............
Old Jul 7, 2011 | 03:39 PM
LS WON's Avatar
LS WON
So which one do you go by or is more accurate? The TPM or your tire guage?
Old Jul 7, 2011 | 03:53 PM
don hall's Avatar
don hall
As posted above, the TPM needs to be energized by movement to provide an accurate reading. (Confirmation required.)
My pressure gage reads 3# higher than the TPMS on 'cold' tires. I will take a reading when stopped after the tires are heated, and compare again. Maybe someone has already done this comparison.
Old Jul 7, 2011 | 04:13 PM
LS WON's Avatar
LS WON
I just take the pressure when tires are cold to get the cold pressure on both readings and notice the difference. The tires warm up when moving and even then there will be a 2 to 3 psi difference.
Old Jul 7, 2011 | 04:22 PM
MAC5's Avatar
MAC5
I have two digital gauges that read exactly the same. One analog gauge that I'd peg at less than one pound lower than the two digitals.
I set the pressure by the digital gauges, 30 psi cold and check pressure about once every two weeks. I let the TPMS do the ALERT work if they run low.
Old Jul 7, 2011 | 04:43 PM
jrose7004's Avatar
jrose7004
Less than 3#.
Old Jul 7, 2011 | 04:54 PM
don hall's Avatar
don hall
That saves me from performing the same test. Thanks.
Makes sense........ MAC5, are any of your gages made by Longacre?
Old Jul 7, 2011 | 04:55 PM
don hall's Avatar
don hall
Less than 3#.
Thanks, Jim. Seems like we are all close.
Old Jul 7, 2011 | 04:59 PM
My TPS reads consistently about 1-2 lbs less than my digital tire gauge. I'm willing to accept that difference.
Old Jul 7, 2011 | 05:07 PM
don hall's Avatar
don hall
Thanks, Jack. Do you inflate your cold tires to 30# based on the digital gage or the TPS?
To Tire Pressure Accuracy
craig04c5's Avatar
craig04c5
My TPMS also reads 2# less then my 2 tire gauges.
Old Jul 7, 2011 | 05:11 PM
don hall's Avatar
don hall
OK, Craig..... same question: Do you inflate your cold tires to 30# based on your tire gages or the TPS?
Old Jul 7, 2011 | 05:12 PM
SaberD's Avatar
SaberD
my sensors are about 3 psi off. their only purpose to me is to let me know if i have a leak or something.
