It is the rubber piece that goes on the passenger side of the top radiator shroud and keeps the coolant lines from rubbing up against the bottom edge of the shroud.
Also, Micah is right - it does keep the condenser line from hitting the shroud.
Thanks for the responses but I am not able to find the location where it would go. Micha says it is "one" of the rubber things, I don't see any others. I tried it in a couple of spots but it just does not seem right.
There is only one of these on the car. The shroud edge gets pushed into the slit in the rubber piece. Here - Mrs. Patches will demonstrate how it goes on for you.
