Brake fluid
Jul 9, 2011 | 11:55 AM
Brake fluid
I'm getting ready to clean/change the clutch fluid on my 2001 vert using the "Ranger Method"....my question is....GM specs DOT-3......Ranger uses DOT-4........what's the difference and is there any problem using DOT-4
Jul 9, 2011 | 04:44 PM
No problem running the DOT4. I believe it has a higher boiling point, and is considered a better quality choice.
Jul 9, 2011 | 07:05 PM
Dot4 is an upgrade.
I use Prestone Dot4 fluid for all my brakes & clutches.Good stuff. I use the Ranger method for all my cars every oil change cycle.
Walmart has it for about $3.
\db2
carolina
Jul 9, 2011 | 08:27 PM
Quote:
Originally Posted by
dbaker
Dot4 is an upgrade.
\db2
carolina
Just did the ranger method to my zo6 last week and used the same fluid
Jul 9, 2011 | 10:18 PM
I also use DOT4, no problems...
Jul 10, 2011 | 10:19 AM
Higher boiling points is true for DOT 4....unless your drivingstyle is hard on brakes, like track cars, DOT 3 will work fine too. Personal preferance.
Jul 10, 2011 | 10:38 AM
I use the Prestone DOT4 synthetic fluid and I get it at WalMart for a great price. Switched over a year ago and have put over 10,000 miles on the car since with no problems. I also use the Ranger method.
You can't go wrong!!
Good luck!!
Jul 10, 2011 | 11:29 AM
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Another Vote for the DOT 4 Fluid!
Thanks,Matt
