[Z06] Oil capacity
Old Jul 9, 2011 | 01:12 PM
cds1's Avatar
cds1
Default Oil capacity
The owner's manual for my C5Z says to add 1 quart of oil prior to performance driving. Of course, I do as it says. After a day of hard driving, the oil level has just about come back down to the "full" mark. If the engine can operate with an extra quart of oil in it, why only run it that with during performance driving. I suspect the idea is to run a quart high so that it doesn't become low on oil. I still wonder why GM didn't just declare 7.5 qt as capacity vs. 6.5 qt.
Old Jul 9, 2011 | 01:44 PM
ZZ06's Avatar
ZZ06
I suspect the extra quart is for those extreme hard left and right turns along with high rpms coming out of it.
Old Jul 10, 2011 | 10:38 AM
spdislife's Avatar
spdislife
Yeah my thoughts too. My car seems to consume 1/2 a quart per track day, give or take.
Old Jul 11, 2011 | 11:53 AM
cds1's Avatar
cds1
My question was if the engine can operate with an extra quart, why not just always run it that way? Just curious.
Old Jul 12, 2011 | 10:17 PM
spdislife's Avatar
spdislife
I'll theorize...with normal driving if the oil is overfilled the crankshaft may be splashing it around. Just a guess on my part.
Old Dec 21, 2011 | 12:16 PM
cds1's Avatar
cds1
I found the answer to this. Under high G lateral forces, oil can get stranded above the valves against the valve covers because lateral the acceleration doesn't permit it to flow back into the oil pan. The extra quart ensures the engine isn't starved of oil if the condition persists for too long.
Old Dec 21, 2011 | 01:33 PM
JimbeauZ06's Avatar
JimbeauZ06
Correct. The extra quart recommendation really wasn't intended for street "performance" driving, but for track driving where the car is sustaining high lateral Gs for extended periods.
Old Dec 21, 2011 | 02:39 PM
JeremyGSU's Avatar
JeremyGSU
I've been confused by this as well. Many people on the forum will tell you to run 7 quarts all the time for both. Which is half a quart higher than the manual but half a quart lower than the track guide.
Old Dec 22, 2011 | 01:46 PM
rayrevolver's Avatar
rayrevolver
My understanding is that too much oil can add drag on the crankshaft and reduce performance.
Old Dec 22, 2011 | 01:49 PM
cds1's Avatar
cds1
Worse than that.. if the crankshaft touches the oil, it can whip it into a foam like substance that can't be pumped! The owner's manual suggests using 7.5 qts for track use, which myself and others have done without any problem.
Old Dec 22, 2011 | 02:30 PM
MY03C5Z's Avatar
MY03C5Z
Adding an extra qt for track use sounds like a good idea. The only problem I see is removing it after. Trying to remove extra oil after an oil change usually turns into a cluster f for me. May as well just change the oil again.
Old Dec 22, 2011 | 06:08 PM
ZedO6's Avatar
ZedO6
I have a fuel pump cutout switch (or just pull the fuel pump fuse). Remove the filter, place a drain pain underneath and crank the engine for a few seconds. Between the cranking and the oil you dumped out of the filter, you will remove at least 1 qt.
Old Dec 22, 2011 | 07:17 PM
MY03C5Z's Avatar
MY03C5Z
Didnt think of just removing and draining the filter, that seems so obvious. The fuse trick sounds like a good idea as well. Thanks
Old Dec 22, 2011 | 08:31 PM
frank dupuy's Avatar
frank dupuy
On the days I go to the track with my 2002 C6-Z06 I make sure my oil stays 1/4 inch above the "full" mark. I never drain any oil out and always drive my car back home sometimes over 200 miles. I have never had a problem just leaving the extra oil in the engine. As the OP originally asked GM only put the extra oil requirement in for the race track and a standard fill would be more than adequate for general driving.
Old Dec 23, 2011 | 08:12 AM
AU N EGL's Avatar
AU N EGL
No problem
that extra oil tends to go out the tail pipe with extended WOT, out of corners.
and yes the best answer is to just change the oil again.
I get about 500 miles to the oil change or two weekends on the track* before the Oil monitor goes from 100% to 30%
M1 15-w50 9 1/2 qts with a 3 qt accu-sump and oil cooler.
* track meaning Road Race course, not drag strip
Old Dec 23, 2011 | 08:21 AM
Bills Z06's Avatar
Bills Z06
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Over the course of a hard day on the track, the engine is going to use some oil. Anywhere from 1/2 to 1 qt in my experience. Just because you add an extra qt of oil, don't think you don't need to check the oil level after each run. Just my .02.
To Oil capacity
