[Z06] ls6 heads
Old Jul 11, 2011 | 10:09 PM
WRIGHTCJW's Avatar
WRIGHTCJW
Default ls6 heads
Looking for some more power . been checking out some heads. I seen from mast motorsports Rectangular Port LS3 11 Degree . They say they will work on the ls6 engine. any input?
Old Jul 11, 2011 | 10:49 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Not sure what your current setup is. I will tell you that my next major purchase for my cammed and LT equipped car will be a good set of heads. More than likely AFR or TRICK FLOW.
Not sure about the LS3. I was under the impression the LS3 ports do not mate well with our LS1/6 cars. But I haven't looked to far into that.
Old Jul 12, 2011 | 12:52 AM
zeevette's Avatar
zeevette
AFAIK, they'll bolt on, but you're gonna need a LS3 intake manifold/TB setup, and then probably a conversion kit so it'll work with you car's computer. Lots easier to buy cathedral port heads, like CNC'd 243s, or Trickflow (my choice) or AFRs. If you have a Z, you already have good heads, with lightweight valves, so you can send them to TEA, and get them modified, and save some cash.
Old Jul 12, 2011 | 04:09 AM
MPM IV's Avatar
MPM IV
100%
Old Jul 12, 2011 | 06:33 AM
AU N EGL's Avatar
AU N EGL
243 heads are still a far better head then LS3 heads. Look at some AFR 215 heads or Trick Flow.
There are a few tuners taking LS3/ L92 heads off the LS3 engines and replacing with PP 243 heads and getting better HP and TQ
Old Jul 12, 2011 | 11:56 AM
WRIGHTCJW's Avatar
WRIGHTCJW
Thanks for the input .
Old Jul 12, 2011 | 12:15 PM
ctusser's Avatar
ctusser
The LS3 heads might work OK in an all out race application for high RPM use. But the port volume on the LS3 head is large which means low flow velocity and will rob your throttle response and low end torque production. Not good for a street car IMO.
Old Jul 12, 2011 | 01:27 PM
mchicia1's Avatar
mchicia1
Yes, which is exactly why it is designed for a larger displacement engine (6.2). I see similar results from GTO guys putting them on their cars. The cars just aren't that fast after the swap. It is not all about max power, which some people never understand. 243's or 799's ftw for us 5.7 guys.
Old Jul 12, 2011 | 04:20 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
This is a case of bigger doesn't mean better.
Old Jul 13, 2011 | 08:44 AM
AU N EGL's Avatar
AU N EGL
Correct and why several builders are putting PP 243 heads on LS3 blocks. Great throttle response and much more low end torque ie OFF the LINE quicker
Old Jul 13, 2011 | 07:20 PM
TXGS507's Avatar
TXGS507
I will have a set of 243's up for sale soon... ( 1 Aug) currently building a H/C car... PM me if interested...
To ls6 heads
