Warm Up Complete
Old Jul 14, 2011 | 08:20 AM
mfile2000's Avatar
mfile2000
Default Warm Up Complete
So as I run down the road, I take a wicked right turn, no one around and plenty of room. I know I'm going in hard and expect some fishtailing. Well, the back gets away from me, I compensate, the back comes back around, I compensate some more, straighten out and proceed down the road and look at the display which reads "Warm Up Complete".....WTF?
Old Jul 14, 2011 | 08:37 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
That is normal, You must of just started up your car not long before you got the message.
Mr.Bill
Old Jul 14, 2011 | 08:38 AM
dndrsn's Avatar
dndrsn
2001 Owners Manual
Page 2-103
Old Jul 14, 2011 | 08:41 AM
DeeGee's Avatar
DeeGee
It happens very occasionally. I've never been able to see any pattern as to when I get the warning.
Old Jul 14, 2011 | 09:00 AM
mfile2000's Avatar
mfile2000
Mr.Bill
That is true, but it was a restart after stopping at an ATM. I guess that doesn't make a difference? So how long after you start your car before you can count on AHS? It was about 100 yards after start to turn, so of course longer than that.
Old Jul 14, 2011 | 09:20 AM
jrose7004's Avatar
jrose7004
I get that a couple of times a year.
Old Jul 14, 2011 | 09:46 AM
killain's Avatar
killain
Oldtimer
Default Alert ?
Mr.Bill
Mine will sometimes do it once a month, and other times it won't display the warning for a year. I think it has something to do with the engine temperature, and the position of your steering wheel. Mine did it yesterday when the engine was cold, but it hadn't come in over a year. Do a search and see what you get. It's been brought up many times here.
Old Jul 14, 2011 | 10:24 AM
Nothing to worry about - all systems normal.
Old Jul 14, 2011 | 10:26 AM
76 VETTE's Avatar
76 VETTE
I get that message occasionly.
Old Jul 14, 2011 | 10:37 AM
Quick Draw's Avatar
Quick Draw
Get that message 2 or 3 times a year. Not sure what triggers it.
Old Jul 14, 2011 | 11:27 AM
dougbfresh's Avatar
dougbfresh
Moving and turning the wheel before all the startup diagnostics on the TC/ABS run is what causes it!
Old Jul 14, 2011 | 12:34 PM
T5Mika's Avatar
T5Mika
I can just imagine your face in the situation...
Maybe it pretends to be an open wheel race car that needs some heat build-up in the tires
Old Jul 14, 2011 | 01:08 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Pull your codes
Old Jul 14, 2011 | 02:21 PM
DeeGee's Avatar
DeeGee
I start in the garage. Idle for a few seconds and then reverse for 50-100 yards. Only then do I turn the wheel. Normally I get the message before I go forward.
Old Jul 14, 2011 | 02:31 PM
mfile2000's Avatar
mfile2000
Originally Posted by dgrant3830
Pull your codes
Ignorance is Bliss!
Old Jul 14, 2011 | 02:51 PM
Mr.Bill's Avatar
Mr.Bill
Pull your codes
Codes, Now why would one pull the codes for a normal operation?
Old Jul 14, 2011 | 03:00 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
You got the end of the message, it should have started with " Traction control warming up " or maybe " Active handling warming up " first, then the " warm up complete".
Just in case you see that again. your traction control light should also have come on for a few seconds.
Someone just asked this exact same question last week, if you had done a search, No thread needed.
To Warm Up Complete
Old Jul 14, 2011 | 03:12 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Interesting...I've never had that message on my '97...I guess it was designed in later on, but when I would like to know. What I do have is tranny fluid temperature, which I know was deleted soon after; I much rather have that data anyway.
Old Jul 14, 2011 | 03:47 PM
mfile2000's Avatar
mfile2000
Nope, my question was more of "Why didn't it kick in when my rear swung out?" Active Handling never engaged.
Old Jul 14, 2011 | 04:20 PM
RC45's Avatar
RC45
Originally Posted by 8VETTE7
Because it was still in the calibration phase and was not yet active. That is wht the warm up complete message was saying.
Bingo.
The system calibrates itself every startup. The car must roll forward for a set distance durin gwhich self test cylces validate all the sensors are functioning correctly before engaging the system.
I used to get the message every day when i daily drove my car - used to often park in a downtown highrise parking lote than included many short straights and lots of turns to get down to street level.
Sometimes the system would be busy for 45 seconds or more until I came to a long enough straight section to finish calibrating.
In that state A/H will not be operational.
