I have to replace the tires on my C5 2004 Coup. The factory tire is the Eagle F1 GS EMT 245/45 ZR17. I am told by Goodyear this is out of production. I would like to stay with the runflat. Any recommendation on a replacement and what the cost should be?
If you are staying with runflats Michelin has their ZP tires that are much better then stock.
I have these: http://www.tirerack.com/tires/tires....+A%2FS+Plus+ZP
I was shocked at how well they perform for an A/S tire.
You don't mention if you are looking for a summer tire or A/S.
close
- Member SinceMar 2001
- LocationIn a parallel universe. Currently own 2014 Stingray Coupe.
- Veteran Field #1C7 of the Year - Modified Finalist 2021
- Veteran Field #2MO Events Coordinator
- Veteran Field #3St. Jude Co-Organizer
- Veteran Field #4St. Jude Donor '03 thru '25
- Veteran Field #5NCM Sinkhole Donor
- Veteran Field #6CI 5, 8 & 11 Veteran
Liked:24,733 Times in 17,577 Posts
Do some research on Tire Rack or similar sites - there are a number of options for you to choose from.jrose7004
close
- Member SinceMar 2004
- LocationOklahoma City OK
- Veteran Field #1C6 of Year Finalist (appearance mods) 2019
Liked:1,825 Times in 1,396 Posts
Sure enough!Originally Posted by Vetteman Jack
