20" Wheels in Front
Old Jul 21, 2011 | 06:07 PM
customizer's Avatar
customizer
Default 20" Wheels in Front
I wanted to know if 20"x8.5 will rub up front? I wanted to run 245/35 Tires.Thanks!
Old Jul 21, 2011 | 07:46 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Just because you can... does not mean you should...
Toque
Old Jul 21, 2011 | 08:07 PM
SFL_driver's Avatar
SFL_driver
Toque
Having a wheel that big will affect your steering and will almost definitely rub.
Old Jul 21, 2011 | 08:33 PM
customizer's Avatar
customizer
Thank You! thats all I wanted to know....
Old Jul 21, 2011 | 10:45 PM
UniqueDoug's Avatar
UniqueDoug
I'll let you know tomorrow, these are due to arrive, but with 245/30's in the front. My tire guy said the 35's will rub. The bottom wheel is the front with 2" lip, naturally the other is the 4" lip rear.
Toque
We already know how you feel about 20's in the front.
Here are some that look nice to me.
Like I mentioned, pulled the trigger on the Ruff Racing wheels and got talked into the 20x8.5 on the front with 245/30/20 Nitto's (285/30/20 rear on 20x10).
Will post some pics tomorrow.
OP, here are some "life saving links" I've been using. Have fun with your research! Key is to keep the diameter the same as the stock setup and to keep the circumference close to the same.
http://www.wallaceracing.com/tire-aspect-calc.php
http://mysite.verizon.net/res0aae8/wheels.html
http://www.rimsntires.com/specs.jsp
Old Jul 22, 2011 | 03:09 AM
JETZ's Avatar
JETZ
Way too skinny/tall, 20's too big.
Old Jul 22, 2011 | 08:53 AM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Vettes have a firm ride as it is, don't understand why you would want your car to feel like your ridding on solid rubber tires, aslo if you hit a good bump, kiss your rim goodbye! just my .02
I run 18/19s and the ride is a lot more firm, can't emagine what 20s would feel like!
Old Jul 22, 2011 | 09:10 AM
UniqueDoug's Avatar
UniqueDoug
It will be an adventure for sure. I went from one extreme to the other. Stock 17/18 to 20's all the way around. I really love the meat on my current setup, saving the wagons just in case!
And my car is slammed on stock bolts.
Naturally I'll post up pics, here is the current set up.
Old Jul 22, 2011 | 10:57 AM
209TIME!!!'s Avatar
209TIME!!!
I really find it funny how some of you can tell someone else about a rim and tire setup that you have never hade on your car. Some of these comments are just plain *** wrong, just people jumping in with opinions...OP just do the research on your own because most of these (opinions) are very biased.
And yes 245-35-20 will rub in the front, I have a 255-30-20 on the front of my car and that was cutting it very close.
Old Jul 22, 2011 | 01:07 PM
groovyjay's Avatar
groovyjay
You could have gone to 15/16 set up for that extra dose of rubber...
Old Jul 22, 2011 | 01:31 PM
UniqueDoug's Avatar
UniqueDoug
Well, UPS was early so here is my new setup. I'm about 95% happy but a perfectionist so that is actually good for me. Thinking back, I've never had a wheel/tire setup I've been completely happy with.
My 245/30/20 does not rub in the front. And the short ride I took seemed better than my 17/18 (I have cheap Sumitomo's on the wagons).
If I had it to do over I probably would go with the 19's in the front but with the tires sizes I went with I still have near the same "stagger" as the stock 17/18 (677 mm height rear 652 mm height front).
I like the way it sits and the wheel gaps are near perfect (may raise the rear 2-3mm).
The Details; Ruff Racing R280 Blk w/machined lip (2"front, 4" rear). 285/30 on 20x10, 245/30 on 20x8.5. Nitto Extreme 555's. $2200 Delivered with tpms sensors.
Old Jul 22, 2011 | 01:47 PM
groovyjay's Avatar
groovyjay
Very
Old Jul 22, 2011 | 02:39 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Looks good, but how much do they weigh?
Old Jul 22, 2011 | 03:33 PM
209TIME!!!'s Avatar
209TIME!!!
Looks nice...
Old Jul 22, 2011 | 03:45 PM
UniqueDoug's Avatar
UniqueDoug
Originally Posted by 209TIME!!!
Looks nice...
Thanks. I'd guesstimate about 3-5 lbs heavier than my repro chrome wagons. I thought they would be much heavier.
Old Jul 23, 2011 | 11:11 PM
customizer's Avatar
customizer
Default New Wheels
I order a new set of Ruff Chrome 281 19x8.5 Front 245 Nitto and 20x10 275 Rear with kit installation shipped to Hawaii $2350.....
Old Jul 24, 2011 | 01:39 AM
209TIME!!!'s Avatar
209TIME!!!
that's a 255-30-20 on a 10 inch wide front wheel.......
To 20" Wheels in Front
Old Jul 24, 2011 | 10:27 AM
UniqueDoug's Avatar
UniqueDoug
Wow, you are brave.
Old Jul 24, 2011 | 10:31 AM
UniqueDoug's Avatar
UniqueDoug
I almost went with the 281. Great price, especially to Hawaii. In keeping with the beach theme, here's one from my roadtrip to Daytona yesterday.
Old Jul 24, 2011 | 11:03 AM
Chicago's Avatar
Chicago
St. Jude Donor '15
You out cruising the retirement villages again?
