Problem when training tire pressure sensors
Old Jul 26, 2011 | 11:18 PM
Patman's Avatar
Patman
Default Problem when training tire pressure sensors
My left front tire pressure sensor died on me a few weeks ago (13 years old and 127,000 miles, not bad!) so I had a new one installed the other day. Today I go about re training it, and it was the first one in the sequence and the horn honked immediately when I put the magnet near it so the new one is good. But when I go to train the right front, it just won't train! The rear ones both train fine. What I don't understand is why that right front sensor won't train when it's been working fine all along (was working right before I trained it!) Has this ever happened to anyone else? Does that mean that sensor cannot ever be re trained, even though it was transmitting just fine before I tried the re training procedure? Will a sensor with a weak (but not yet totally dead) battery simply not re train? It's also one of the original sensors, along with one of the two rear ones too (yes, I had three original sensors still, which is pretty amazing when you think about it!)
Old Jul 27, 2011 | 12:42 AM
Patman's Avatar
Patman
I'm not sure how much stronger of a magnet I can find, I was at a friends house and he had a bunch of very huge magnets on the bottom of some tool trays (for keeping nuts and bolts in place) and he also had a couple of old speakers with big magnets too. With all of the magnets we tried, 3 of the sensors would train within a second or two, so I'm thinking those magnets were about as strong as I'm gonna find.
Old Jul 27, 2011 | 01:48 AM
DeeGee's Avatar
DeeGee
Its not a problem I've heard here before.
If the front left is beeping it means you're getting into the programming sequence so I'd say its not the magnet on this occasion. If all but one sensor trains then I'd suspect that that specific sensor is bad. I just don't know why you're not getting XXX on that sensor on the DIC. Is it still giving a reading of pressure even though it wont train? Run the car for a couple of miles and see if it gives a reading. You'd think it would transmit its old data if it hasn't been recalibrated. Bear in mind that training is just telling it where it sits on the car. It already knows its a TPS. As you say, maybe just enough to send a signal of sorts but not enough to train.
If it was me I'd replace all the original sensors now. 13/127k is almost a record I'd say.
Old Jul 27, 2011 | 07:07 AM
Patman's Avatar
Patman
Nope, it doesn't give a reading anymore. The first time I went through the training, and the R right didn't give me a horn honk, I thought I'd go for a drive and see if the pressure would still show up on the DIC since it had been working just minutes prior to this. But only the L front would show a pressure. I tried a few more times and then thought I would just skip that tire and see if the rears would train. They did, so as it sits now, my DIC thinks the R rear tire is actually the R front, and it thinks the L rear is the R rear, and it's showing a blank for the L rear spot. It just sucks to have to replace a sensor that was working perfectly fine before the training sequence And it's not like the 97-00 sensors are cheap either, even off E-Bay I paid a little over $100, although I did opt to go for a brand new OEM sensor. Maybe this time I'll go aftermarket or get one of the rebuilt OEM sensors for $35.
Old Jul 27, 2011 | 03:11 PM
DeeGee's Avatar
DeeGee
Looks like the RFA is not seeing the sensor. Just confirm it's an original?
Old Jul 27, 2011 | 03:35 PM
Before you go out and buy a new sensor - try this: Place a magnet over the sensor location in the barrel of the wheel. I had a difficult time training mine on my new wheels but when I placed the magnet like described above, it allowed the sensors to sync. Just a thought.
Old Jul 27, 2011 | 04:09 PM
DeeGee's Avatar
DeeGee
What I dont understand Jack is why that one doesn't train yet the others do. If the magnets strong enough for one its normally good for all of them. Still seems like that particular sensor is dying
Old Jul 27, 2011 | 05:31 PM
Patman's Avatar
Patman
I did try that as well, and it still didn't work. The three other sensors had no problem with this magnet held at the end of the valve stem, they trained within a couple of seconds. But I tried all kinds of positions with the magnet on this one sensor, to no avail. So I guess this one has given up the ghost.
Old Jul 27, 2011 | 09:57 PM
Was a surprise to me too. My RF sensor wouldn't train no matter how many times I went into the train program, yet the others would work with the magnet around the valve stem. Finally took the advice of another forum member and put the magnet on the barrel of the wheel over the sensor and bingo, it worked.
Since that obviously didn't work for the OP, then yea, the sensor may be dead.
Old Jul 28, 2011 | 10:39 AM
Patman's Avatar
Patman
Since I had an extra sensor lying around, I sent it off to a guy on E-bay who rebuilds them for just $35. It will probably take a couple of weeks (due to shipping time) so I will let you guys know how it turns out.
Old Aug 1, 2011 | 11:22 PM
Patman's Avatar
Patman
I got a message today saying that my old sensor was not rebuildable, he didn't say why though. So I ended up ordering a new aftermarket sensor (Dorman) from RockAuto, it was $65 CDN. ($35 less than the OEM one I just bought)
Old Aug 1, 2011 | 11:31 PM
Qwik01's Avatar
Qwik01
How did you get to the training mode on the car?
Old Aug 1, 2011 | 11:34 PM
Patman's Avatar
Patman
Hit the options button and keep hitting it until you get to a blank screen. Then hold the reset button for a few seconds and the first thing that pops up is fob training. Hit the options button again and it'll toggle to tire training. Then hold the reset button down again for a few seconds and it will begin the training, asking you to start with the L front tire first, and then it moves clockwise around the car (as long as each sensor trains that is, if a sensor won't train then it won't let you continue with the others).
Old Aug 10, 2011 | 09:02 AM
Patman's Avatar
Patman
So my Dorman sensor arrived yesterday and I just got back from having a tire shop install it for me. It gave me a scare though, because even though the horn honked when I trained it, before getting it put into the tire, on the drive to the shop that sensor showed xxx on the display, I was expecting it to show 0psi instead. And after getting it installed, it took a lot longer to show a pressure than the other sensors, they all showed the pressure in less than a 1/4 mile of driving, but the new one took at least 2 miles. I hope it isn't going to be like that every time I restart the car again. Maybe that's the way the aftermarket sensors act though? Although as long as it does work eventually, I suppose it's not the end of the world
Old Aug 10, 2011 | 10:31 AM
DeeGee's Avatar
DeeGee
Glad you finally got a good sensor
I wonder if that's just the initial reading or if it'll be slow on every start up? Let us know.
Old Aug 14, 2011 | 05:48 AM
Patman's Avatar
Patman
Buying this Dorman sensor was a huge mistake!
When I drove the car for a second time this week, it took so long for the sensor to "come online" that it triggered the "service tire mon system" message first! And then after that, it didn't work at all for the rest of the day, until later on when I drove it to a car show, coming home it finally worked again, but only after about 10 miles of driving. This sensor is garbage!! I should have bought OEM! Live and learn! And in the end I didn't save that much money, as Rock Auto ended up charging me more for shipping, plus they charged me sales tax, while the previous OEM sensor I bought from E-bay had no tax and lower shipping charges. I think I saved $17 with the Rock Auto sensor, but it cost me $40 to have the tire removed and reinstalled, so now eventually I'm going to have to pay to have that done again.
To Problem when training tire pressure sensors
