Swapping out gauge clusters.....
Old Jul 31, 2011 | 04:47 AM
vetteman741's Avatar
vetteman741
From: Motorsports Capital of the World..Indianapolis Indiana
what is a clove box.....
..........or a guage?
Old Jul 31, 2011 | 08:01 AM
wascapsfan's Avatar
wascapsfan
3 Hours??? Glove box???
Remove the radio bezel,
remove the knee surround (under the steering column) or just move it aside and leave the light plugged in
remove a few screws that you did the last time
Remove the 2 silver nuts immediately under the steering column
lower the steering column just until it hits the stops (couple of inches)
Remove the trunk/foglight switch
Remove the 2 screws at the top of the gauge
telescope the steering wheel towards you as far as possible (auto on steering column)
push down on the gauge cluster to lower the top of the cluster then raise the entire cluster so that the plastic hook on the bottom of the cluster clears its orifice
remove the heads up plug if you have one
remove the huge plug in the cluster and slide out the gauge
Total job 19 minutes
You probably didn't push the plug in until it CLICKED!!!
pm if you have a problem
I'll walk you through it or you can send it to me for LED's!!!
Old Jul 31, 2011 | 01:13 PM
Sinister-one's Avatar
Sinister-one
Wow..... that was VERY helpful......
Old Jul 31, 2011 | 02:31 PM
wascapsfan's Avatar
wascapsfan
Hopefully you are doing well with this project.
Let me know if you are having issues.
I'm 90% certain that you didn't get the plug all the way in.
Very little goes wrong with these unless you sit it upside down for long periods of time.
Old Jul 31, 2011 | 03:51 PM
MotoJB's Avatar
MotoJB
Old Jul 31, 2011 | 04:43 PM
Sinister-one
Started working on it and almost had it apart when my wife decided she wanted to help my daughter move out of her college apartment. So I've got to stop for a bit and go lend a helping hand.
I'll post my findings when have all apart.
Old Jul 31, 2011 | 06:55 PM
wascapsfan's Avatar
wascapsfan
Please do. You sold me the gauge rings and helped me out so I will certainly help you out.
We WILL get this figured out as I'm certain that your plug is just not in to the snap. It MUST hit the snap (click) ALL the way in or you will have an absolute dead display and that includes the Heads up as that is plugged into the top and must also be inderted all the way in but there is no click on that. There is NOTHING else other than a plug not pushed in ALL THE WAY that will wipe out EVERYTHING, other than a dead fuse which you already confirmed was fine.
PUSH that plug in ALL THE WAY and I guarantee you will have a big smile on your face. Also... for the future...if you take your gauge out, ALWAYS leave it sitting facing forward or up, never leave the display facing down for any period of time..(Half hour or so is ok) the units are fluid rich and must be left upright or sideways (like you see it when installed in your car). That will also create nightmares!!!!FYI
Old Jul 31, 2011 | 08:27 PM
Sinister-one
okay just got done taking EVERYTHING apart and checked the connections..... guess what... still nothing. I went so far as to reconnect my old cluster and it worked perfectly ! Everything works on the swap-out cluster except the back lights.
I'm thinking there's an internal problem with my new/used cluster.... And REALLY wanted to use the new cluster.
Old Jul 31, 2011 | 10:36 PM
BaadGoat2006's Avatar
BaadGoat2006
I have thought about adding a z06 cluster to my car and want to know if there is a "learn" procedure for the cluster install.
Old Jul 31, 2011 | 11:04 PM
Sinister-one
yes, and this is it...
Originally Posted by ajg1915
Yes,
The easist way to remove it is to remove;
- Radio Bezel
- Knee Bolster
- Lossen Steering column bolts underneath (2) 13mm.
- Use T15 to remove Upper Screws and lower screws and then slide it out.
And it worked out great ! But my new cluster still didn't light up...
Old Aug 1, 2011 | 07:55 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Check fuse #6 in passenger footwell.
Old Aug 1, 2011 | 09:07 AM
Sinister-one
It's non of the fuses. I re-installed my original cluster back in last night and it works perfectly. There must be something wrong with the repacement cluster I put in.
UPDATE : I was reading another thread with someone having the same problem I am. Looks like the cluster may have a bad power supply which operates the backlights !!
Old Aug 1, 2011 | 01:18 PM
  #33
wascapsfan's Avatar
wascapsfan
Ok...that sux
Old Aug 1, 2011 | 09:26 PM
  #34
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You might want to CF member tstar (aka Tim) he's pretty knowledgeable about these.
Tony
