Swapping out gauge clusters.....
Old Jul 30, 2011 | 04:26 PM
Sinister-one's Avatar
Sinister-one
Default Swapping out gauge clusters.....
Swapping out gauge clusters..... WHAT A P-I-T-A$$ !!!
Hope you guys never REALLY have to go through that. It took me 3 hours and the entire dash has to come apart. I can honestly say I'll never do that again unless I REALLY haved to !
Old Jul 30, 2011 | 04:30 PM
Stealth_Inc's Avatar
Stealth_Inc
3 hours? Just for the gauge cluster? Sounds about right haha. First time i did it it took about 3 hours. After that (done it three more times due to gauge face add-ons and problems with it) i can take it out within 20 minutes. lol.
Old Jul 30, 2011 | 04:41 PM
Sinister-one
Take it all out and put it all back together is 20 minutes !! I'd like to see that.
Old Jul 30, 2011 | 05:12 PM
RJ1AZ's Avatar
RJ1AZ
From: PHOENIX, AZ Yes, it's true. You are a good woman. Then again, you may be the Antichrist.
It could be done. Have to have all the right tools laid out and know exactly what you're doing.
I took mine out a couple times to do LED's and gauge trim rings. The first time was slow. Didn't want to screw anything up. The next time went MUCH faster.
Old Jul 30, 2011 | 06:22 PM
sfc rick's Avatar
sfc rick
20 minutes...all the time. Have all the tools needed, magnetic dish to hold the screws and 4 6mm nuts.
Piece of cake. Hold the steering wheel down after depressing the column adjust lever. Gage cluster literally jumps out.Tilt leftside down and out past turnsignal lever, tilt rightside down and out to clear windshield wiper lever. pull leftside cluster out to unplug wiring harness.
I've done this soo many times.....The center console, radio bezel, knee bolster, and gage cluster almost takes itself apart if I pick a torx driver up! LOL!
Old Jul 30, 2011 | 06:27 PM
Sinister-one
sorry but there's no way it all comes apart and goes back together in 20 minutes.... maybe an hour or so....
Old Jul 30, 2011 | 07:11 PM
Sinister-one
Okay guys, now I have a problem..... I closed up the garage to check the gauge lights and guess what..... NO GAUGE LIGHTS !!!!
Any ideas as to where to start checking ???
Old Jul 30, 2011 | 08:03 PM
Sinister-one
What about the HUD connection ??
So... the dash pad and the glove box DON'T have to come off ??
Old Jul 30, 2011 | 08:23 PM
thetaxman's Avatar
thetaxman
takes me just under an hour and that is w/o hand jobbing the screws
I have a small 1/4 inch drive electric screwdiver that is made for doing interior work
I can get it out in about 10 minutes
but
I take my time putting it back together
Old Jul 30, 2011 | 09:31 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Check fuse #4 in tha passenger footwell and for loose connections. ALso make sure you turn up the back lit switch if it got switched off by accident.
Old Jul 30, 2011 | 10:09 PM
Sinister-one
I'll check the fuses. And I already did the backlight switch, nothing happened. Could the gauge backlight / HUD switch be bad ??
Old Jul 30, 2011 | 10:15 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I'll check the fuses. And I already did the backlight switch, nothing happened. Could the headlight / HUD switch be bad ??
I would presume that your headlights worked fine before the conversion (upgrade), so I would look only at what you added.
Hud switch, wire harness, illumination adjuster, fuses and make sure all of your connections are tight.
Old Jul 30, 2011 | 10:26 PM
Sinister-one
Everything worked perfect. Just checked the fuse, nothing wrong with it..... looks like I'll be pulling the WHOLE dash apart again tomorrow.... there goes 3 hours again...
Old Jul 30, 2011 | 10:29 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Start early as it gets hot out there very quickly at this time of the year.
Old Jul 30, 2011 | 10:31 PM
Sinister-one
nice....
can the cluster be removed without removing the dash pad and the glove box ?
Old Jul 30, 2011 | 10:34 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
nice....
can the cluster be removed without removing the dash pad and the clove box ?
Yes,
The easist way to remove it is to remove;
- Radio Bezel
- Knee Bolster
- Lossen Steering column bolts underneath (2) 13mm.
- Use T15 to remove Upper Screws and lower screws and then slide it out.
Old Jul 30, 2011 | 10:38 PM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
nice....
Yes! Just drop the steering column!
To Swapping out gauge clusters.....
Old Jul 30, 2011 | 10:53 PM
Sinister-one
Yes,
- Radio Bezel
- Knee Bolster
GREAT !! Will get on this first thing in the A.M. !
Thanks guys.
Old Jul 30, 2011 | 11:06 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Hopefully it's a quick fix.
Old Jul 30, 2011 | 11:10 PM
wetelvis's Avatar
wetelvis
Ditto
